The VSV on water outlet housing is usually referred to as a "bi-metal" valve or canister purge valve. Its not terribly expensive from the dealer. Should be around $60. Replaced mine last month but I have the 5S-FE. Not sure if the V6 uses the same part #.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door.  New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
