Help me with weird no start issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-27-2009, 11:47 AM   #1 (permalink)
View Shapeup1's Photo Gallery
I have a 1993 camry 6 cyl 3.
Never have a problem starting it, turn the key and bang it starts.
Two days ago I turned the key it did the motion but didn't catch. Suprised I turned the key again and it started no problem.
Fast forward yesterday, I did a couple of short trips and no problem, then in the afternoon I go to the grocery store , when I go to start it spins but didn't start, tried several few time nothing. (now inside I'm starting to freak out)
I walked back home went back an hour and half latter nothing doesen't start.
Went back this morning turned the key and it started WTF??
Drove it back home and will try again in half an hour see what happens, but its driving me crazy on what can it be? Also does this car hold in memory errors so the mechanic can scan it?
What do you guys think? Thanks kindly for your help
Shapeup1 is offline   Reply With Quote
Old 12-27-2009, 12:56 PM   #2 (permalink)
View toyomoho's Photo Gallery
Not all engine systems are linked to code readout.
Any difference in starting when engine is hot, set for say 30 minutes or cold started in the morning?
Old 12-27-2009, 03:05 PM   #3 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $908127
iTrader Score: 59 reviews
Sounds like Starter contacts!
Random not starting
^^I did a search for you!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
eyeball96 is offline   Reply With Quote
Old 12-27-2009, 03:12 PM   #4 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Color me clueless, but it sounds like the engine is turning over but not catching -- that ain't starter contacts.
Old 12-27-2009, 03:17 PM   #5 (permalink)
hill8570's Avatar
I'd like to know the same thing.
Also, are you set up to pull a spark plug (or maybe you've got a spare spark plug available) when this happens so you can check for spark?
Old 12-27-2009, 03:23 PM   #6 (permalink)
Not much difference, with the engine hot it starts faster.(like on contact) Cold it takes like half a second more.....
Since bringing it home this afternoon I went out twice and it started on contact.
Old 12-27-2009, 03:30 PM   #7 (permalink)
Random not starting
Thanks for the search friend, but it always turns....
Old 12-27-2009, 03:57 PM   #8 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
hmmm I think it could possibly be a spark/ignition issue. Have you had a tune up recently? If you never have, new plugs, wires and rotor might solve the prob.
Next time it doesnt wanna start take a spare spark plug and pull off one of the wires. Then ground the plug with the wire on and see if its sparking.
Does/did it run fine when it was rainy outside in the morning?
carsrus is offline   Reply With Quote
Old 12-27-2009, 04:40 PM   #9 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
How many miles? Do you have a CEL? I'm wondering if the ECT is going open when it feels like it. Could be intermittent CPS as well.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
Old 12-27-2009, 04:55 PM   #10 (permalink)
hill8570's Avatar
IIRC, this rig uses individual coil packs fired through an igniter (and the igniter has a separate trigger line for each coil pack). No rotor. If this turns out to be a spark issue, I'd think the most likely possibilities would be the ignition switch (specifically, the IG2 side of the switch, such that no B+ at the igniter) or possibly a bad connection or ground to the igniter. Off chance other bad / loose connectors, too. Bitch to trace this down when it's intermittent.
Just can't see how bad plugs or wires could give a no-start condition. Might run rough as crap, but no-start doesn't seem likely.
Have some starting fluid ready to squirt into the intake manifold for the next time this happens would also be useful -- if this is a no-fuel issue, starting fluid should at least make 'er try to catch.
Old 12-27-2009, 05:01 PM   #11 (permalink)
Super Moderator
eyeball96's Avatar
Maybe I'm reading into it but, spins, isn't cranking, and I don't see catching as cranking either.
I had the same problem with the daughter 96, you'd turn the key, and nothing, after a few more tries, it would "Catch"...and then Crank!
Your not clueless, but maybe I am! If the engine Cranks, your right it ain't starter contacts
98 Honda CRV
08 GMC Crew
Old 12-27-2009, 09:08 PM   #12 (permalink)
View flyeri's Photo Gallery
What spins? Engine or just starter motor? Sorry if I missed this somewhere.
flyeri is offline   Reply With Quote
Old 12-27-2009, 10:21 PM   #13 (permalink)
Custom fab's my specialty
Leviathan66610's Avatar
View Leviathan66610's Photo Gallery
...Um, well... Alot of things spin. The crankshaft and the flywheel are the main components that spins only because of the starter turning them, but the timing belt connects that also to your camshafts which in turn also spin just not as fast.
Leviathan66610 is offline   Reply With Quote
Old 12-27-2009, 11:23 PM   #14 (permalink)
hill8570's Avatar
But who's on first?
Old 12-28-2009, 12:19 AM   #15 (permalink)
lol well it's all simultaneous. But I guess you could say technically the starter spins first.
