Excessive fogging/ice build up - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-28-2009, 10:43 PM   #1 (permalink)
Slowly learning....
View Retrospekt's Photo Gallery
When I drive in humid conditions like snow or rain, the inside of my windows fog up like crazy. Doesn't matter how many people are in the car with me. Sometimes ice builds up on the inside of the windshield also. I know this probably has something to do with air leaks and the car being old.
How much am I looking at to replace weather stripping?
1996 Toyota Camry | 4 Cyl. 2.2L | Black Paint with Tan Interior | All Stock | DEAD at 155k. Broken Crankshaft/Main Bearing
Retrospekt is offline   Reply With Quote
Old 12-28-2009, 11:50 PM   #2 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $349653
View BMR's Photo Gallery
I can't answer the question you asked, but I have to ask; do you run the A/C in those conditions? It helps enormously to do so.
BMR is online now   Reply With Quote
Old 12-28-2009, 11:56 PM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Did you run AC? Also, make sure the drain tube is not clogged and that condensate can flow out.
Old 12-29-2009, 12:02 AM   #4 (permalink)
Slowly learning....
I did not run the A/C. I can't even imagine having to do that if it's snowing outside.
Where is the drain tube located?
Old 12-29-2009, 12:14 AM   #5 (permalink)
View Kenny_McCormic's Photo Gallery
Guys, this is not an AC problem, its the middle of winter in Chicago! Are you using defrost? Do you know what defrost is/does?
Kenny_McCormic is offline   Reply With Quote
Old 12-29-2009, 12:43 AM   #6 (permalink)
Gameroom cash: $167485
iTrader Score: 6 reviews
View haux's Photo Gallery
The A/C doesn't make the air colder... it "conditions" it. Hence air "conditioning." I have no idea how to explain it but the air quality is better. If I turn the A/C off and have the heat going in cold weather, my windshield will fog up. Then I turn the A/C back on, switch over the defrost and the fog goes away.
2000 Toyota Camry LE (Japan made) i4 5S-FE 367,000+ miles.
haux is offline   Reply With Quote
Old 12-29-2009, 01:11 AM   #7 (permalink)
The cabin moisture comes from people breathing.
Defrost just blows the air toward the windshield. On many cheap Toyota models it doesn't even engage the AC compressor. You have to do it manually.
But normally elsewhere defrost engages the AC compressor. The further drop in cabin temperature decreases the moisture the air can hold, and the moisture condensates out. OP has to make sure the moisture drains out the drain tube and that's not frozen shut.
Old 12-29-2009, 01:20 AM   #8 (permalink)
Slowly learning....
I use my rear defroster and I point the heat at all the windows/windshield. I'll try air conditioning next time, but when I say I fog up, I mean INSTANTLY. I get in the car, start it up and while I'm waiting for it to warm up it fogs up within a minute.
Where is the drain tube?
I did hear that excess moisture (snow on shoes) can cause the moisture to rise up and freeze on the inside of my windshield, which I think is what happened today since I was pretty careless after entering my car.
And remember, this is Chicago. 17 degrees Fahrenheit outside right now.
Old 12-29-2009, 01:37 AM   #9 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3626750
+1
With my Avalon I have to add the A/C manually, but with my Highlander the A/C is turned on automatically in both defrost modes. Running the A/C works miracles. Also, clean the inside of your windshield. Dirt, oils, dust, etc., act as nucleating particles that moisture form around, much as they do with rain or snow. You'd be amazed at how less quickly your windshield will fog up and, if it gets fogged up at all, how quickly it will clear if the inside of your windshield is clean.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 12-29-2009, 01:42 AM   #10 (permalink)
TOYODA KAMURI
the_professional's Avatar
View the_professional's Photo Gallery
I never run my A/C, and my windows never fog, I understand it is different with you guys, as with friends who also use A/C when defrosting.
Make sure air is on "outside" air, not recirculate, and fog goes away in less than a minute. I am glad it is manual, I hate running the A/C. & like TD said, keep your windows clean.
i love my 1992 Toyota Camry LE 2.2L 5S-FE - 73K
9005 NIGHT GUIDE LOW BEAMS|FOG LAMPS|PIONEER HU&AUDIO|KEYLESS ENTRY
1995 Acura Legend LS KA7 3.2L C32A - 87K
SADLY, SHE HAS MUCH MORE MODS...
the_professional is offline   Reply With Quote
Old 12-29-2009, 02:19 AM   #11 (permalink)
My A/C control unit (2000 Camry) has a button for A/C, Recirc, and Rear Window Defrost. So, the A/C button basically stayed pressed at all times. Once I push it in it stays that way. I see no reason to turn it off since it makes the air quality a thousand times better. I never use the Air Recirculation button either.
Old 12-29-2009, 09:30 AM   #12 (permalink)
View White95Cam's Photo Gallery
John is correct. Cars with auto set climate control engages the a/c compressor in defrost mode. It removes the humidity from the cabin that comes from respiration and damp clothes. The compressor cycles in short bursts and does not effect the level of heat. I believe that the build up in moisture comes from the fact these cars are so well sealed. I actually use this configuration more in the rainy summer months than during the winter. If there is a low dew point then I don't have any fogging issues.
W95c
White95Cam is offline   Reply With Quote
Old 12-29-2009, 09:42 AM   #13 (permalink)
Gameroom cash: $302547
View ricamryman's Photo Gallery
I have VentVisors installed on my windows, if I get some fogging, I crack a window, & the fog clears right up.....
ricamryman is offline   Reply With Quote
Old 12-29-2009, 09:50 AM   #14 (permalink)
View Lightning Blue's Photo Gallery
Does the 2001 Camry turn on the AC with the Defrost or do I have to do it manually?
2001 Camry LE - I4 - 138,xxx miles
2005 Neon SXT - 47,xxx miles
Lightning Blue is offline   Reply With Quote
Old 12-29-2009, 07:11 PM   #15 (permalink)
That happens on cold mornings above freezing. Doesn't have to be Chicago winter.
Sure, let us know how manually engaging the AC works. Depending on how "warm" your cabin is at the time, the compressor may or may not engage. But just turn it on, let it decide its own work and let us know.
The drain tube is center towards the passenger side, just rear of the fire wall. If yo look under the car at that spot, you should see the very tip of a rubber hose sticking out of the floor pan. Often it's clogged up with spider web and such. Maybe in Chicago it's just iced up?
