The standard Fujitsu-Ten alarm re-labeled as Toyota?
The control unit is a box slightly larger than a deck of cards. Depending on how lazy the tech is, it's usually under the driver side dash. The competent ones typically follow the Fujitsu-Ten instruction and install it near the steering column way up. The lazy ones just tie wrap it much lower so it's easy for you to "see".
Fujitsu-ten used to have a fax back number that'll give you detailed directions on how to wire things up. However, according to the following, this fax back no longer works. (310-327-9905)
http://www.tundrasolutions.com/forum...lling-fujitsu/
Originally Posted by Judd sandage
I found out mine was made in Kentucky in Feb of '98 so I am assuming its a '98 model year, I was wondering where the factory installed remote entry/alarm system might be located? also bear in mind I cant get the passenger door open for now so getting in to that side is a pain, I should have that fixed by this weekend.
