Decreasing Mpg :'( - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-31-2009, 12:42 AM   #1 (permalink)
View Manny1337's Photo Gallery
Decreasing Mpg :'(
As the title states ive seemed to loose mpg. I was at about 28 and now i usually get around 22ish. Same driving nothing extra in car. Could it be the o2 sensor or bad plugs? i haven't gotten around to checking the plugs yet because its pretty cold up here. Any typical reason this would happen? No check engine no problems with her at all.
1998 Camry I4 2.2 Currently: 110k
Alpine Ida-x100, Polk Momo 6x9 (Rear), Polk DB651 (Front), Infinity Reference 475a, AudioQ Aq-1200, 4 Re X 8's <-- yes she slams
Manny1337 is offline   Reply With Quote
Old 12-31-2009, 01:42 AM   #2 (permalink)
'98 Camry Owner
View Judd sandage's Photo Gallery
I would check your trans (assuming that its an auto), while driving do you notice that it runs at a higher RPM then before? check to make sure that o/d is turned on, with it off you don't get cruising gear and hence lower gas mileage.
'89 Toyota Camry Wagon I-4 auto (Stolen, got back with everything ripped off they could get, Sold it)
'93 Ford Taurus sedan (Totaled Sold for scrap)
'95 Pontiac Bonneville (Trans died, Selling for scrap)
'98 Toyota Camry LE 4 Door I-4 Auto (work in progress)
Judd sandage is offline   Reply With Quote
Old 12-31-2009, 02:33 AM   #3 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
When's the last time you checked your tire pressure?
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 12-31-2009, 05:36 AM   #4 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Using gas with ethanol will reduce mileage by at least 10%. So much for the cheaper price.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 12-31-2009, 05:59 AM   #5 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
Yeah, a winter gasoline blend with Ethanol could be the culprit.. Next I'd check your tires and air filter.
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
Old 12-31-2009, 10:13 AM   #6 (permalink)
Well the trans isnt driving in any higher rpm and od is kept off. its not the gas because it just started doing this (its been winter for a little bit) and i check my tire pressure every week, anything else? =P
edit: and the air filter is clean checked it the other day
Old 12-31-2009, 10:33 AM   #7 (permalink)
View The international's Photo Gallery
checked compression?
The international is offline   Reply With Quote
Old 12-31-2009, 10:47 AM   #8 (permalink)
nope i have not, do not know how nor do i have the tools =P.
i just pulled one of the spark plugs to check it there was corrosion all on it. im assuming thats not too great of a sign. i put the plugs in last year they are bosh platinum =(
Old 12-31-2009, 11:11 AM   #9 (permalink)
Go to the repair shop 'cause I don't know either . Though maybe this can help you http://www.automedia.com/Checking_Co...ht20020701cr/1
Old 12-31-2009, 05:26 PM   #10 (permalink)
View yotatoter's Photo Gallery
the mileage sometimes decreases in the winter ,not sure why other than poor gas or engine temp. not running as hot
yotatoter is offline   Reply With Quote
Old 12-31-2009, 05:47 PM   #11 (permalink)
TOYODA KAMURI
the_professional's Avatar
View the_professional's Photo Gallery
I'd really get rid of the BOSCH plugs when you can.
BOSCH is shit in our cars, and they are known to fail prematurely. I would just bite the bullet, get rid of them & get some NGKs.
i love my 1992 Toyota Camry LE 2.2L 5S-FE - 73K
9005 NIGHT GUIDE LOW BEAMS|FOG LAMPS|PIONEER HU&AUDIO|KEYLESS ENTRY
1995 Acura Legend LS KA7 3.2L C32A - 87K
SADLY, SHE HAS MUCH MORE MODS...
the_professional is offline   Reply With Quote
Old 12-31-2009, 07:24 PM   #12 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
02 sensors begin to lose efficiency around 100K miles and that effects gas mileage.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 12-31-2009, 07:42 PM   #13 (permalink)
'98 Camry Owner
well, if you do a lot of highway driving I would recommend to turn on OD as that allows the rpms to drop for cruising. better gas mileage that way.
Old 01-01-2010, 06:41 AM   #14 (permalink)
Unless the engine is missing I doubt plugs or wires. Either the spark lites the fuel or it does not. Longer heat-up times during winter will consume more fuel, but once the engine is hot you should get same mileage - more so because you're not using A/C. If you know how you could test the o2 sensor and the ECT (engine coolant temp sensor). A small investment in a Haynes Manual would show you how, and save you some money. Compression test might help but without an earlier base measurement you won't know if it's degraded and by how much. Slightly grabbing brake will also reduce mileage - check wheels for difference in heat. Other than that you'll need to take it to a mechanic as you'll spend money on unnessessary parts taking guessed suggestions from us - we aren't psychics.
Old 01-01-2010, 11:55 AM   #15 (permalink)
Gameroom cash: $197815
View Frodo65's Photo Gallery
Are you one of those 'brilliant' folks with remote start? Doing more 'warm-up' idling, like to defrost the windows? These factors would kill the MPG by themselves - idling engines get 0 MPG.
One 'semi-normal' thing, made worse by cold weather, could be a thermostat that's a bit off, and opening sooner (or not closing completely). This would keep the engine from getting to normal temp as soon as it should, and cause it to burn more fuel. The semi-normal part is that thermostats do age, and can stick open (or closed) as they do...
I'd recommend a OBD scan gauge to keep an eye on various engine parameters as the car is running. You can find one for $100 or so. There are a number of scan gauges/OBD readers on Amazon and stores like Harbor Freight. Note that unlike a simple code reader, the scan gauge lets you monitor the data stream in the ECU, even when no DTC is stored. This lets you see things like a 'lazy' O2 sensor or an 'off' TPS or MAP sensor.
Frodo65 is offline   Reply With Quote
