Will these fit? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-01-2010, 12:49 PM   #1 (permalink)
View JBlacks's Photo Gallery
Will these fit?
http://indianapolis.craigslist.org/pts/1532845449.html
trying to put these on a 1993 camry v6. I will start searching to see if i can find the model number for more info. Didnt know if someone would know what they are just from seeing them.
JBlacks is offline   Reply With Quote
Old 01-01-2010, 01:01 PM   #2 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
You could always buy them and find out! if not, sell them at a higher price
Chris Crash is offline   Reply With Quote
Old 01-01-2010, 01:09 PM   #3 (permalink)
the offset is 35, 8.5 inches wide, 245/45 zr 19 tires.
Old 01-01-2010, 01:12 PM   #4 (permalink)
Those sound a little big.
But then again, I don't know gen 3's.
Old 01-01-2010, 01:47 PM   #5 (permalink)
[g4.Rep]
Gameroom cash: $245932
View ONE_to_HATE's Photo Gallery
id rock those sizes! .. - but ya, those would fit but yr going to have to pull yr front fenders a little and pull yr rear fenders then use 225/35-19 tires, get sum /--------\ (camber) in the back and front and yr golden!!
-don't make the wheels fit the fender, make the fenders fit the wheels!
http://i55.tinypic.com/oa6dj8.jpg
[TRD.jpn][TRD.usa][5Zigen][DDM][DENSO][BC][STICH][FEDERAL][STANCED]
ONE_to_HATE is offline   Reply With Quote
Old 01-01-2010, 02:02 PM   #6 (permalink)
christine
cocacolagrl's Avatar
View cocacolagrl's Photo Gallery
i dont recommend putting 19 inch on a 93..it will ruin you suspension and the car wont be able to take it....i wanted 17s and my dad said no way b/c of this reason...so i went up 1 inch from 14 to 15 inch and the ride got so much worse just going up one inch.....but....if you decide to get them..they will fit...i got my rims from tirerack...and the pattern is 5.114 and they are a perfect fit....
i have a 92 le..
cocacolagrl is offline   Reply With Quote
Old 01-01-2010, 03:46 PM   #7 (permalink)
thanks for the help guys ill keep looking. im just looking for some cheap rims to replace my bent rims from the pot holes
Old 01-01-2010, 04:28 PM   #8 (permalink)
View bcp477's Photo Gallery
This touches on an issue little understood by many. If you want to preserve the RIDE of the car (evn somewhat), then DON'T decrease the aspect ratio of your tires much.....as well as stay away from increasing the weight of each wheel/ tyre assembly much. In a practical sense, this means NO "plus 2", "plus 3", etc. conversions. 14" to 19" is ridiculous.....though I am sure that it is "cool" to some. If you care only about handling and looks - that is a different story. But, "plus 1" is about the farthest one should go, if ride is at all important. And incidently, preserving some of the ride will also pay off in the longevity of the suspension. Drastically larger diameters, which ALWAYS add a good deal of weight.....will ALWAYS greatly increase wear and tear on the suspension, leading to the necessity of spending $$ on new struts and bushings A LOT more often than normal. As to "improved cornering"......with a huge increase in wheel/ tyre diameter, eventhough the tyres will have a much lower aspect ratio..... cornering will only improve on SMOOTH surfaces. Greatly increasing unsprung weight at each corner will only lead to hopping and loss of grip on bumpy roads (most of the public roads, after all). Remember, a suspension system is just that - a SYSTEM. This includes the wheels and tyres. If you want to drastically change ONE item....you'll need to re-work the ENTIRE system to suit.
Just because they might fit......or could be made to fit.....does NOT mean that it is a good idea. Just as jumping off a bridge, just because your idiot friend did it, doesn't necessarily make for a good idea. THINK it through, before acting.
bcp477 is offline   Reply With Quote
Old 01-01-2010, 04:38 PM   #9 (permalink)
im just looking for cheap wheels to get me by. im not used to dealing with small cars so thank you for the info.
Old 01-01-2010, 04:45 PM   #10 (permalink)
christine
you can get nice new rims from tire rack...for less than 300.00 not with tires....the bad thing about tire rack is they dont carry 14 inch so thats why i went up one more inch.....i got four sport edition 15 inch for 278.00 and its another couple hundred for tires....its worth it though...they really look great on my car....
Old 01-01-2010, 06:07 PM   #11 (permalink)
anyone tried these on a toyota? http://indianapolis.craigslist.org/pts/1533229022.html
Old 01-01-2010, 10:57 PM   #12 (permalink)
[g4.Rep]
^^ too small.
do the 19" !! - they'd look balls out.. plus the 225/35 on 8.5 width are stretched so they're gonna look extra sexxxy! ... thats gonna be crazy.
Old 01-02-2010, 12:57 AM   #13 (permalink)
quangtran89's Avatar
iTrader Score: 8 reviews
View quangtran89's Photo Gallery
19", Over price tires. lol
Check the offset LINK and see if they will fit your car. I have 7.5" now with 45 offset and with these wheels I have have 3mm less from the wheel to the strut. My rear wheels with tires are about 1-2mm from the strut. This set up will not work for me unless I use spacers and roll my fender a bit.
As for ride comfort, if I wanted to keep it I wouldn't have even think about modding the car.
quangtran89 is offline   Reply With Quote
