(could you check my math on this)
I've got a similar problem, but could you check my math/ reasoning.
I pulled the switch out, and tested with an connectivity light tester. I did not use any test equipment to know how much power was going through the wires.
There are 5 wires at the switch.
Blue, Red, Red w/ Black Strip, Green, and Green with Black Stripe.
I believe that the Blue wire carries the positive side of the current and the striped wires carry the negative side of the current. The tester lite up when I connected the blue wire with either striped wire, or with the body ground. No other combination seemed to light the tester.
Using the two amp setting from the battery charger, I direct connected to the red wire and the red striped wire. (nothing moved) The result was the same when I connected the battery charger power to the green and green striped wires. I think that means the window motor is broken.
Did I think this through correctly??
