Car cranks in neutral not in park? Won't start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-02-2010, 05:56 PM   #1 (permalink)
View cj0609's Photo Gallery
3rd Generation Car cranks in neutral not in park? Won't start
I have a 92 2.2.Drove to work the other night and was low on gas. Came out to leave and the car would crank but not turn over , and eventually died. Jumping the car didnt work. I changed the battery, battery cables and the connectors. I put in some dry gas and three gallons of regular gas. Still nothing. I tried to roll the car while in nuetral and start it but it still will only crank. After doing that it will only crank in nuetral. In park the dash lights come on but I get nothing when I turn the key. Why is that? Does something happen to the alarm when you use that shift lock button to put it in nuetral. I made sure the car was all the way in park. I dont know. Thinking ignition coil as to why car wont turn over? I smell gas up front when stepping on the gas so I assume gas pump is working. My distibutor ,cap and rotor, plugs and wires ,fuel filter were all changed three months ago.
cj0609 is offline   Reply With Quote
Old 01-02-2010, 06:17 PM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3626750
The fuel filter is still a possibility even though you changed it a few months ago. If you actually sucked the tank dry, then the sediment that had collected there since 92 could have been pulled into the fuel line and clogged the filter. Worth a look.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 01-02-2010, 07:17 PM   #3 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862710
View BamZipPow's Photo Gallery
Do you have an alarm system?
Confirm that all yer fuses are good. The neutral start switch could be bad. Are you sure the shifter linkage is still good and aligned?
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is offline   Reply With Quote
Old 01-02-2010, 07:34 PM   #4 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
Sounds like the park/neutral switch.
Note that this is not the same thing as the neutral safety switch! The park/neutral switch is near the ignition.
Chris Crash is offline   Reply With Quote
Old 01-05-2010, 07:32 AM   #5 (permalink)
my main concern is the car not turning over. Only recently did I have the problem with the car only cranking in nuetral. The reason that started was I had to move the car from where it was and put it into nuetral without the key by using tha button by the shifter that enables you to do that. I am going to disconnect the battery and see if that solves that problem so I can crank the car in park.. As far as the car not starting, I am going to check the fuel filter. After that someone suggested the ignition coil. Unfortunatly the auto parts store wants $95 for that part . I might try ebay.
Old 01-05-2010, 03:38 PM   #6 (permalink)
View Kenny_McCormic's Photo Gallery
Check for spark.
Kenny_McCormic is offline   Reply With Quote
