belt vs pulley vs harmonic balancer - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-03-2010, 12:28 PM   #1 (permalink)
asphalt victory's Avatar
View asphalt victory's Photo Gallery
so ive had this squeal under the hood for a while i always figured it was the decrepit power steering belt BUT now it sequels when i turn on anything with an electrical draw the radio the lights the stereo the defroster so now im thinking its something else
i looked and what im seeing is the forward pulley the forward one the power steering belt shares with the accessories belt and i think im looking at a worn harmonic balancer because its vibrating more than the other ones
can anyone help me with this?
thanks mike
MAY AN EMPTY PARTS BOX BE MY WINNING TROPHY
asphalt victory is offline   Reply With Quote
Old 01-03-2010, 02:05 PM   #2 (permalink)
View yotatoter's Photo Gallery
i had a 92 with the v6 that harmonic balancerfailed,half of the inside of the balancer came out,so i had to get a new one,,try checking your alt. belt tension they need to be adjusted periodically,,if its loose tighten your alt.
yotatoter is offline   Reply With Quote
Old 01-03-2010, 02:53 PM   #3 (permalink)
im afraid of tension it too much i think i got the cheapest belt and it will probably break on me 400 miles away from home at 2 am in a cell dead zone haha
plus the bottom pulley is wobbling OR appears to be i will go tighten it right now and see if that helps
Old 01-03-2010, 04:33 PM   #4 (permalink)
View bcp477's Photo Gallery
If the harmonic balancer pulley is "wobbling"..... this likely means that it is coming apart. The pulley is in two or more pieces, held together with rubber molded in between (which is designed to dampen vibration). The rubber can deteriorate.... thus the pulley comes apart. You need to replace the harmonic balancer - it's as simple as that.
bcp477 is offline   Reply With Quote
Old 01-03-2010, 04:38 PM   #5 (permalink)
ok hahaha broke the tensioner bolt off fun i hope i can still drive it?
Old 01-03-2010, 08:53 PM   #6 (permalink)
Camry Expert/MR2 JR Xpert
jtex2717's Avatar
Gameroom cash: $272115
View jtex2717's Photo Gallery
Wouldnt Suggest it.....Get a new Balancer now and Tensioner bolt.......I would suggest u take it to a professional.......
Finally Red MKII MR2 5s & Metallic Blue 96 Cam 1MZ
Watch out for the build thread!!!
IM BAAAAAACK!!!!!!!
jtex2717 is offline   Reply With Quote
Old 05-09-2010, 05:25 PM   #7 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Would this be what you're talking about? Im assuming that when you remove it to replace it, you want to make sure that the timing mark is lined up at TDC so that when you install the new one it's all good, or does it really matter? This just happened to mine and my car is done until I get this fixed. Have to call in to work tomorrow to get it done.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 05-18-2010, 03:17 PM   #8 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
But if the rubber bonding the two parts is compromised, the timing marks may not line up anyway because the two parts have moved when the rubber failed.
The good news is; its OK, because the dampner pulley has a keyway that only allows it to fit one way.
Hopefully it doesn't do too much damage on the way out!
73sport is offline   Reply With Quote
