Aftermarket garbage? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-05-2010, 12:44 AM   #1 (permalink)
Gameroom cash: $167485
iTrader Score: 6 reviews
View haux's Photo Gallery
Recently I threw a lot of money at my car to make it a comfortable ride once again.
I didn't cheap out on the brands.
Nevertheless, some of these new parts are showing rust only a month later? What's going on?
Raybestos reman calipers. Raybestos sway bar links. Raybestos control arm bushings. A1 Cardone reman halfshafts. The o-shaped bushing for the control arm is showing rust all around it. My ORIGINAL stuff after 338k miles didn't have nearly as much rust as these brand new parts.
I'm starting to wish I went with OE on this stuff.
We recently got some snow... so I'm sure everything has salt all over it. But still, I've spent winters up north with this car, and the original parts looked excellent.
2000 Toyota Camry LE (Japan made) i4 5S-FE 367,000+ miles.
haux is offline   Reply With Quote
Old 01-05-2010, 12:50 AM   #2 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
Yeah, when I got my struts replace the nuts and bolts rusted within a month. I would just rust-proof them.
I don't know if a spray rust-proof exists? but if it does, try that.
Or just paint everything next time... Like the calipers etc. Just paint them
Chris Crash is offline   Reply With Quote
Old 01-05-2010, 12:55 AM   #3 (permalink)
I bought black caliper paint... but I looked at the calipers. How the heck do you paint them? There are rubber components... and then the piston. Do you have to take them completely apart?
I tried painting a little piece of metal with pink engine paint, outside in 20-something degree weather, and the paint just balled up and wouldn't stick to certain parts of the metal. Does temperature matter? I don't have an indoor climate controlled place to work in.
Old 01-05-2010, 12:57 AM   #4 (permalink)
Temperature makes a HUUUUUUUUGE difference. It won't adhere well to metal that's too cold. I believe around 70 degress or higher is the best.
As far as the calipers, Just cover the rubber lines with tape and paper. And same with the pistons.
Old 01-05-2010, 01:00 AM   #5 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $992475
View MR2Jedi's Photo Gallery
Yes, temperature makes a big difference. Really needs to be above 55 degrees.(it's in the directions)
As far as painting the calipers, you will have to remove them and tape them off-when you get a warm enough day.
I want to paint my valve cover before I put the engine back together, but it's been hovering around freezing. I'll just have to wait.
The Jedi Speeder at CarDomain
Old 01-05-2010, 01:04 AM   #6 (permalink)
I painted my VC and exhaust shields just last week. It was probably around 35 here. The exhaust shield paint held really well, the VC.....not so much. hahaha.
Can you paint in your garage MR2?
Just having walls make a ten or fifteen degree difference in temperature alone. And then you can use portable heaters and heat lamps to heat up the area around the painting and it will not only stick well, but dry and cure very well with the added heat from the lamps.
Old 01-05-2010, 01:10 AM   #7 (permalink)
Should I rub the calipers down with a scuff pad prior to painting?
Also, I fear there won't be a warm day in January. The weather likes to tease me with upper 30's sometimes, and some sun. But right when I think it may warm up... BAM. 20. =| ...fucker.
Old 01-05-2010, 01:16 AM   #8 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I have a covered carport. I was thinking about hanging some tarp all the way around the 2 open sides and putting a heater in there. Idunno
I just had my whole valve train upgraded-
http://www.toyotanation.com/forum/sh...12#post3030512
So I wanted to install the head this weekend.
I was trying to think of a way to block the wind and warm things up alittle. Even if I could get it itno the 40's I'd be happy.
Old 01-05-2010, 01:23 AM   #9 (permalink)
Yeah scuffing it will help. Just make sure its clean, is the main thing. Like I said, If you can bring it in your garage or something maybe that will help.Shit you could probably bring it in your house, just open the windows and have fans blowing the spray fumes out the windows.
Old 01-05-2010, 01:26 AM   #10 (permalink)
Tarp will definietly block the wind, but it won't realy insulate a whole lot...
Maybe with enough lights and heaters it could work though! If you've got some plywood sheets lying around, or know a close construction site you can "borrow" from, utilize those to make an added barrier on the sides. Old carpet/padding can be found behind carpet stores, that will definitely insulate. I would hang padding before tarp. Blankets will work well too.
Old 01-05-2010, 01:57 AM   #11 (permalink)
A camry n00b
peshwa's Avatar
Gameroom cash: $257859
View peshwa's Photo Gallery
Angry CarDONE is CRAPDONE
Recently noticed that my left front outer CV joint boot was torn/squirting grease/clicking etc...replaced that with $60 crapDONE CV Axles and ......the clicking still continues... but without the grease I feel stupid I traded my OEM axle that lasted me 165K miles for a piece of $hit that Cardone is.... (smashes his hand on the cv axle and gropes for answer to "Who tore my CV boot"?)
1995 Camry DX L4 178,6XX miles and counting each mile.... acquired 05/25/2007 at 129K miles
2004 Mazda6 I4 5-Speed Manual 115,500 miles acquired 01/21/2011 at 109,XXX miles
peshwa is offline   Reply With Quote
Old 01-05-2010, 02:07 AM   #12 (permalink)
Originally Posted by peshwa View Post
Recently noticed that my left front outer CV joint boot was torn/squirting grease/clicking etc...replaced that with $60 crapDONE CV Axles and ......the clicking still continues... but without the grease I feel stupid I traded my OEM axle that lasted me 165K miles for a piece of that Cardone is.... (smashes his hand on the cv axle and gropes for answer to "Who tore my CV boot"?)
Wait, did the boot tear again? Or does the new one look fine but still clicks? Maybe the clicking is coming from somewhere else?
I probably shouldn't have labeled A1 Cardone as quality... but that's the ONLY option RockAuto offered for my 2000 Camry.
Old 01-05-2010, 02:34 AM   #13 (permalink)
A camry n00b
peshwa's Avatar
^ No the boot hasnt torn again..thankfully till now...the CV axle is clicking..damn sure about it :-( I try to back up the car in reverse with steering wheel turned all the way to left...that bitch still clicks..I am mad as hell now...
Anyway I will poke my head outa the window tomorrow again and hear some noises again...
Old 01-05-2010, 02:37 AM   #14 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Did you install all the parts by now? Or are there some non-OEM ones that you can still return?
Old 01-05-2010, 03:09 AM   #15 (permalink)
Is it still under warranty? o.o
