2000 I4 Camry owners, I need your help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-05-2010, 03:26 AM   #1 (permalink)
Gameroom cash: $167485
iTrader Score: 6 reviews
View haux's Photo Gallery
This is sort of a spinoff of this thread: Signs of fuel pump problem?
Bottom of page five are some videos.
I need some of you to pay attention to your RPMs at startup when low fuel light is on. And then pay attention to the RPMs on startup immediately after fueling.
When fuel is low, and immediately after fueling, when starting up, my RPM goes up to 1200-1400, then drops down to 600, hesitates/shudders for 2-3 seconds, then goes up to about a normal 700-800. One time recently, the *drop* went down to 200-300 RPM for three seconds. Again, this only happens when fueling after the low fuel light has come on. So, fuel was very low. *Normal* startup is approx. a jump to 1200-1400, and then it settles down at 800.
I am only noticing this now. I'd like to believe that I would have noticed it over the past six years if it had ever happened before.
Entire fuel pump assembly was swapped out with one from a 56,000 mile Camry. No change.
I need a few owners of this identical type of vehicle to do test this. Let your fuel light come on one day... drive another five miles or so. Get some gas. Then on startup pay close attention to your RPMs. Car should be fully warmed up when this happens. Do they do anything out of the ordinary?
If other users have experienced this, then I guess the mystery is over.
2000 Toyota Camry LE (Japan made) i4 5S-FE 367,000+ miles.
haux is offline   Reply With Quote
Old 01-05-2010, 12:29 PM   #2 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
Like I said in your other thread, when I get mine running again, I'll take some videos for you!
Chris Crash is offline   Reply With Quote
Old 01-05-2010, 02:39 PM   #3 (permalink)
Do let me know if that gets done. Would be great. =)
Old 01-05-2010, 03:42 PM   #4 (permalink)
Got 'em! How do I upload them is my next question...
Old 01-05-2010, 03:53 PM   #5 (permalink)
View My Video
sorry I couldn't find how to embed it...
EDIT:
By the way, that's not from with an empty tank.
Had 3/4 of a tank. First time starting it after dropping it in a new car
This was also after roll-starting it, as it does not currently start the conventional way.
Old 01-05-2010, 09:18 PM   #6 (permalink)
01 Camry LE 5S-FE
View stefan27UF's Photo Gallery
I'll check it out on my '01 as soon as my tank gets lower-might be a week though...I've been walking enjoying the freezing florida temps
stefan27UF is offline   Reply With Quote
Old 01-05-2010, 11:59 PM   #7 (permalink)
Yes, and it's also not of the *startup*.
But when it's complete enough to start normally, do pay attention to the rpms on startup when the low fuel light is on. And then also immediately after fueling.
View My Video
EDIT:
Old 01-06-2010, 12:00 AM   #8 (permalink)
That would be most excellent, thanks.
Old 01-06-2010, 08:11 AM   #9 (permalink)
View Lightning Blue's Photo Gallery
Water in your tank perhaps?
I don't usually let mine get so low, but I'll try it this time and see what it does.
2001 Camry LE - I4 - 138,xxx miles
2005 Neon SXT - 47,xxx miles
Lightning Blue is offline   Reply With Quote
Old 01-06-2010, 08:24 AM   #10 (permalink)
Wouldn't the water have filtered out by now? This is a persistent "problem" on startup after getting gas when fuel is extremely low.
Thank you though! Just be sure not to run out of gas. I'll tell you though... I have never run out of gas in my car. And I can drive 30+ miles after the low fuel light permanently comes on. I'm unsure how much above thirty... I don't really want to find out, hehe.
Old 01-06-2010, 09:03 AM   #11 (permalink)
My Neon claims that it'll blink the low fuel light at 1/16 of a tank but I've never been brave enough to take it down that far.
I've run out of gas once, in my old 1995 neon, cause I wasn't paying attention to the gas
As far as I knew, water in the tank might stay there, you might try a bottle or two of heet and follow it up with the more expensive "complete fuel system" cleaner, I swear by those things!
Old 01-06-2010, 09:26 AM   #12 (permalink)
That's very interesting... as I just looked up, gasoline indeed floats on water, so IF there was water in the tank, it'd be sitting at the bottom for quite some time. Unsure how that would cause something like this to happen though.
Maybe it's worth me getting a gallon in a portable tank, running my gas low, and sucking out whatever is left in the tank?
As for cleaners... I've tried seafoam recently, but not much else.
Old 01-06-2010, 09:40 AM   #13 (permalink)
Has it always happened? If not, that's why I thought of water.
Heet:
http://www.goldeagle.com/brands/heet/default.aspx
Old 01-06-2010, 09:49 AM   #14 (permalink)
Heet:
It started fairly recently. Fyi, the first post has a link to the initial thread. Bottom of page 5 has videos.
I will buy a bottle of heet today at the convenience store when I get gas.
Old 01-06-2010, 06:45 PM   #15 (permalink)
'95 Camry LE coupe
View MurderedOut's Photo Gallery
Could it maybe be the cold weather? I don't know anything about this..just a thought
MurderedOut is offline   Reply With Quote
