1998 Camry 4-cyl. heating problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-06-2010, 04:02 PM   #1 (permalink)
View N600's Photo Gallery
4th Generation 1998 Camry 4-cyl. heating problems
I have a 1998 Camry LE 4-cylinder with about 98,000 miles on it. The main problem is that it blows just 'warm' air unless I'm on the highway...I have changed the anti-freeze/coolant, changed out the thermostat, and put on a new radiator cap; it is only slightly better than it was.
I have read through the forums, and I am still at a loss as to what to do about it!
N600 is offline   Reply With Quote
Old 01-06-2010, 06:57 PM   #2 (permalink)
O-Dark-30
frenum49's Avatar
View frenum49's Photo Gallery
hmm
You probably need to flush out your heater core. Remove the coolant lines that are going from the engine side coolant lines that run into the firewall and shoot water from a hose into the core both directions a couple times until the water runs clear without rust. Should do the trick.
frenum49 is offline   Reply With Quote
Old 01-06-2010, 09:23 PM   #3 (permalink)
And how, pray tell, am I supposed to do that in the dead of winter with no garage?
Old 01-06-2010, 09:27 PM   #4 (permalink)
O-Dark-30
frenum49's Avatar
You want heat? Not my problem that you dont have a garage. If you c ant do it yourself go pay a mechanic or stop asking for advice.
Old 01-06-2010, 09:30 PM   #5 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862710
View BamZipPow's Photo Gallery
Talking
If you want heat...you can either pay someone to do it fer you or do it yerself. You can build a temp shelter with some plastic tarp and use a small space heater to heat up the area under the tarp. Sometimes you gotta do what you need to do to save money...but that's up to you what yer gonna do.
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is offline   Reply With Quote
Old 01-06-2010, 10:44 PM   #6 (permalink)
Up yours too then.
Old 01-06-2010, 11:17 PM   #7 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
Hey...
Can't we all just get along and bake some cookies or something?
Chris Crash is offline   Reply With Quote
Old 01-06-2010, 11:28 PM   #8 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Originally Posted by Chris Crash View Post
Hey...
Damn, where's the :kumbyyah: smilie when you need one?
Old 01-06-2010, 11:40 PM   #9 (permalink)
I wish this was Facebook and I could like your post..
