Does gas spoil? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-06-2010, 09:52 PM   #1 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
4th Generation Does gas spoil?
Does gas ever go "stale"?
I'm sure it does a little, but does it to the point where it can fuck up anything/rob HP?
Reason I'm asking is that the camry I just swapped into had 3/4 tank full....from 3 years ago. And I wanted to know if I should take the trouble to drain it or not. I was going to drain it originally, but then I saw the filler neck doesn't go straight into the tank.
I noticed that the engine and transmission doesn't seem as fast as it was in my old camry. I'm hoping the reason is just crappy gas or something I can at least fix. I'd like to get that engine's pep back!
Chris Crash is offline   Reply With Quote
Old 01-06-2010, 10:05 PM   #2 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
Yes, gasoline can go bad. It eventually turns into varnish. If sucked up into the engine, it will gum up/clog the fuel pump, fuel filter, fuel injectors, and may lead to costly repairs. I'd never trust 3-year-old fuel for anything other than cleaning off dirty car parts. I'd would rather spend money on a fresh tank of fuel, than the headaches of a gummed up/clogged fuel system. If the fuel has to sit for a long time, add some fuel stabilizer like "STA-BIL". It'll keep the fuel fresh.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 01-06-2010, 10:12 PM   #3 (permalink)
Gameroom cash: $127997
View jordan7831's Photo Gallery
Also if the fuel has to sit for a long time, try to keep it in a SEALED container. This will keep any water vapor from getting in, thats why gas tanks are pressureized!
BTW as a point of interest, a rule of thumb is you can keep gas for about a year max in a sealed container. When you use it, just add small amounts to a tank of new gas.
jordan7831 is offline   Reply With Quote
Old 01-06-2010, 10:15 PM   #4 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
^^^ +1
Usually you can dilute the old gas with fresh to point the old stuff is "usable", but 3/4 of a tank is a bit much.
Old 01-06-2010, 10:16 PM   #5 (permalink)
Sooooooo.....I should drain it and fill it with new gas?
Old 01-06-2010, 10:18 PM   #6 (permalink)
Yes!
Old 01-06-2010, 10:20 PM   #7 (permalink)
Alright. How should I do that? Just unhook the fuel filter and turn the car on, let the fuel pump pump it all out?
Old 01-06-2010, 10:25 PM   #8 (permalink)
hill8570's Avatar
Why no just pop out the fuel pump (under the back seat) and siphon? You're not building a church here...just get most of the old gas out before filling up with fresh.
I'd think the tank would have a drain, too, but never had to drain a Camry tank so I could be mistaken....
Old 01-06-2010, 10:28 PM   #9 (permalink)
uibalnme's Avatar
Yeah, there should be a drain plug. You'll just have to look for it.
Old 01-06-2010, 10:33 PM   #10 (permalink)
I'll look for a plug tomorrow when I get it up on the lift. If I can't find it, then I'll siphon I guess.
Old 01-06-2010, 10:54 PM   #11 (permalink)
I dug up this link for you
If the link does not work type "dumb woman puts diesel in a gas corolla"
Its about someone who put diesel in a car by mistake, but the process is the same. Hope this helps!
Old 01-06-2010, 11:16 PM   #12 (permalink)
"dug up"? Or was it more like that was your corolla? hahaha.
I bet that killed the cat having all that shit run through it.
Thanks for the link though! I'll consider doing this tomorrow.
Old 01-07-2010, 12:33 AM   #13 (permalink)
Gameroom cash: $167485
iTrader Score: 6 reviews
View haux's Photo Gallery
That guy is effing funny.
2000 Toyota Camry LE (Japan made) i4 5S-FE 367,000+ miles.
haux is offline   Reply With Quote
Old 01-07-2010, 07:44 PM   #14 (permalink)
So I went to my old auto tech shop again today and asked my old teacher about this. He said to just fill it up with fresh gas and it'll be fine.
Old 01-08-2010, 11:01 AM   #15 (permalink)
View djb2's Photo Gallery
The current pump gas is chemically far different than the gasoline of old. It's more likely to gel, cause rubber to deteriorate and cause metal to corrode. It's less likely to turn into varnish.
If your area mandated alcohol in the gas, the corrosion inhibitors have long since been depleted. But there isn't much you can do about that now.
If the gas is still liquid and the car runs, just top off the tank and drive as usual. For the first tank or two you might not let the level get below about half, then you should run the tank nearly empty and get a tank of fresh gas. This will dissolve any gel, and leave a fresh layer of full-strength corrosion inhibitors inside the tank.
Don't change the filter immediately. Fuel filters are large and can handle large quantities of contaminants before clogging. But if you do plan on changing the filter, wait until a tank or two of fresh gas has been used. There isn't much point in changing out a good filter, only to have the new one immediately catch everything in the tank and lines.
The same is true of the oil and filter. Run the car until it's fully warm before changing the oil and filter. You want all of the gunk washed off the engine and suspended in the oil.
djb2 is offline   Reply With Quote
