D Drive light busted - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-07-2010, 11:09 PM   #1 (permalink)
View arthur.aaragon's Photo Gallery
I am annoyed because the D drive on the speedometer doesnt turn on when the gear is on D. The rest of the gears are ok except for D. Could this be replaced? and if yes, is it hard to do?
TG4567
arthur.aaragon is offline   Reply With Quote
Old 01-07-2010, 11:13 PM   #2 (permalink)
'95 Camry LE coupe
View MurderedOut's Photo Gallery
use the search button there are quite a few threads on this
MurderedOut is offline   Reply With Quote
Old 01-07-2010, 11:41 PM   #3 (permalink)
Gameroom cash: $167485
iTrader Score: 6 reviews
View haux's Photo Gallery
All of the gauge cluster bulbs can be replaced. The black frame pries out, with two screws up top. Then four more screws for the cluster itself.
2000 Toyota Camry LE (Japan made) i4 5S-FE 367,000+ miles.
haux is offline   Reply With Quote
Old 01-08-2010, 04:59 AM   #4 (permalink)
Gameroom cash: $302547
View ricamryman's Photo Gallery
My drive light on the dash did the same! No biggie, every other gear selector light works.....
ricamryman is offline   Reply With Quote
Old 01-08-2010, 09:15 AM   #5 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Easy fix. See the DIY for this at DIY: Gen 3 "D" Bulb replacement .
Matter of fact, take a look at the rest of the DIY threads at Camry FAQ ------> READ FIRST -----> Comprehensive List of Gen 3/4 INFO and DIY -- lots of good stuff there.
Old 01-08-2010, 09:54 AM   #6 (permalink)
Wow! Thanks! I have a project to do this weekend!
TG4567
Old 01-08-2010, 10:05 AM   #7 (permalink)
#2!
Gameroom cash: $102128
View #2!'s Photo Gallery
Grab 11 or 12 of those bulbs and just replace them all at once. I replaced my D bulb and had it all back together and then my back lit bulb burned out. Then my O/D light. I think those things get old and brittle and when breaks them when your tearing into stuff.
#2! is offline   Reply With Quote
Old 01-08-2010, 10:47 AM   #8 (permalink)
View djb2's Photo Gallery
Or you can take the quick approach of just swapping the never-used '1' lamp in place of 'D'.
Note that this doesn't fix the problem where slightly moving the gear selection lever causes the 'D' light to go on.
djb2 is offline   Reply With Quote
Old 01-08-2010, 11:14 AM   #9 (permalink)
View WISHYWASHY's Photo Gallery
mine has been busted for years, i just assume when nothing is lit the car is in D
WISHYWASHY is offline   Reply With Quote
Old 01-08-2010, 11:33 AM   #10 (permalink)
Chemist at Chevron
Gameroom cash: $314885
View bdy0003's Photo Gallery
Mine was off for years and for some strange reason started working a few months ago, however dimmer than the rest.
bdy0003 is online now   Reply With Quote
Old 01-08-2010, 12:41 PM   #11 (permalink)
'95 Camry LE coupe
[quote=djb2;3034087]Or you can take the quick approach of just swapping the never-used '1' lamp in place of 'D'.[quote]
That's what I did! But since I have been driving so long without the "D" light I don't like having it on now haha
Old 01-08-2010, 01:53 PM   #12 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
Dude, just swap in the 5 speed. Then you don't have to worry about those lights!
Chris Crash is offline   Reply With Quote
Old 01-08-2010, 01:56 PM   #13 (permalink)
hill8570's Avatar
In keeping with your "murdered out" theme, you should pull all of your lights. Now that's black-on-black, baby!
Old 01-08-2010, 04:56 PM   #14 (permalink)
asphalt victory's Avatar
View asphalt victory's Photo Gallery
i wear glasses my winsheild is scratched to hell and my headlights are stuk down and out (driveing at nite is tricky) and i find the darker the instrument pannel the better/less distracting for my eyes if the high beam light and dummy lights were hooked up to the dimmer switch i would be even happier the "D" light is a bounus not having to look at it
plus i allways thought that was norman?
MAY AN EMPTY PARTS BOX BE MY WINNING TROPHY
asphalt victory is offline   Reply With Quote
Old 01-08-2010, 10:28 PM   #15 (permalink)
Justin
JJ9284's Avatar
View JJ9284's Photo Gallery
haha so true maybe I should do that since my D bulb is out
1995 Camry
JJ9284 is offline   Reply With Quote
