anyone know what could be causing this. Whenever i put the gas down real hard like 75% or more the car seems to vibrate like it wants to die. Its not extremely noticeable but ive driven the car long enough that it didnt do it before.
The car is inching closer to 100k miles (its at around 95500) and im trying to get some maintenance done. i just had the first timing belt replace about a month ago. i put some seafoam in my gas tank so i can clean the injectors.
the car also recently started smoking when being first started up in the morning. i know its nothing to worry about accept to keep an eye on it and to check the oil regulatory now
but does anyone know what could be causing the vibration and if i should be worried about it
lmk thanks
97 Camry: 17" Enkei rims, lowered with Ground Control and tokico,
Alpine head, mids, and highs, rockford 4-channel, 12" P3 rockford,
MTX monoblock, TRD RSB, Clear Corners, 6K Mod Express HID kit
i dont know if its a misfire. i have an exhaust on the car so id probably be able to hear if i had a misfire but im going to check the plugs and probably clean the throttle body
the butt dyno feels the same when accelerating i dont feel like ive lost power
Yeah, if this started after the belt got done its possible the belt might be off by a tooth. However usually the idle would be bad and the engine wouldent be smooth at all really.
Balancing problems show up over 60 or so, doesn't matter how much throttle you have on it. With the car running, take a garden hose to the ignition system, mist it until its dripping wet, if it coughs or dies, you need wires or have a bad coil pack. Plugs are cheap and can do some goofy shit, especially at 50K old.
cleaning the TB will fix sticky gas pedal, rough idle, and hesitation coming off idle, but won't make any difference above 50% throttle opening. never hurts to do it though, as it will affect low-speed driveability.
btw - time to update your signature.
__________________ 98 Camry CE v6 5s 97 MX-5 95 Camry SE v6 2dr SC (sold) www.gibson99.com
YOU GUYS. Vibration under hard acceleration is a classic sign of bad half-shafts. Seen it a hundred times. Replace your axles. They are only $65 new each anyway.
