Hi all. I have a 94 Camry with a 2.2 4cyl. It died on me while I was leaving for work. It cranks but won't start. I didn't hear the fuel pump so I jumped it and it does work. But when I try to start the car, I don't hear the pump turn on. I have the back seat removed so I can hear better. I also checked 1 spark plug and the coil wire and got no spark in either. All fuses are good. I don't know what to check on the relays. I don't know where to go from here. Could it be the coil or the ignitor? I did replace the radiator a week ago. The was the last work I did to the car, but I'm sure that has nothing to do with the problem. The car was given to me and its been great until now.
Thanks for your suggestions. The timing belt is broken. I started working on it today. I'm stuck on the crank pulley. I don't know how to hold the pulley in place so I can loosen the bolt. My Haynes manual says stick a screwdriver in the flywheel, but isn't that behind the lower timing belt cover? I don't think I should grab it with pliers or vice grips. That might break or damage it. I have the upper cover off, alternator and bracket, and the top engine mount. So once I get the crank pulley off and the lower cover, I should be able to start putting the new belt on. I'll get back at it tomorrow. Its 20 degrees out and I need a break.
There is a small cover on the bell housing that needs to be removed to wedge the flywheel. You can bump the starter with a breaker bar properly placed on the frame to remove the crank pulley bolt. Easier than flywheel method IMHO. Impact guns are nice.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo, I did your starter trick. Put the socket on and leaned the breaker bar against an old 15" rim. That was a piece of cake. I'll be putting the timing belt in later in the week. Too much other stuff going on work, wife, kids...Thanks for all the help.
