92 Camry Drivers Window Problem, Help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-10-2010, 07:00 PM   #1 (permalink)
View malangon's Photo Gallery
I started having a problem with the driver's side window on my 92 camry. The window would be sluggish in going down and up. Then one day, it completely stopped moving. I opened the door up and found the regulator blown up. The enclosure that holds the cables had broken open.
I ordered a new regulator online and installed it without a problem. But when I tried to get the window up or down, it wouldn't move.
Here's the puzzle:
When the window is taken out, the regulator works fine. It raises and lowes without issue. When I put the window in and 1 (ONE) bolt is connect to the window clip, the window raises and lowers fine. The problem is that the second bolt doesn't line up right. What I have to do to make it fit is connect the window and then push the piece to fit into the holes in the door. I think this is the cause of the problem.
So here's the question: Do I drill the regulator bracket to allow for a better fit or can I remove one of those clips on the bottom of the window and reposition it for a better fit??
malangon is offline   Reply With Quote
