1997 Removing and repairing leaking washer bottle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-10-2010, 08:18 PM   #1 (permalink)
View txtony's Photo Gallery
4th Generation 1997 Removing and repairing leaking washer bottle
Apologize if this should come up on an easy search of the forum but no luck for me.
Found that washer bottle must be leaking and see that some use epoxy to fix. Don't mind trying that first but may just get another one and change.
However, what is the process to remove the washer bottle? I presume somehow from underneath. Did a quick look in the Haynes manual and did not see right away either.
Thanks for the help!
txtony is offline   Reply With Quote
Old 01-10-2010, 09:31 PM   #2 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
If you can access the leak without removing it, you should just epoxy it back from there. It will hold up stronger than a new one will.
Just make sure you sand the area well, and don't be stingy with the epoxy!
Chris Crash is offline   Reply With Quote
Old 01-11-2010, 02:39 PM   #3 (permalink)
View .Camryman97.'s Photo Gallery
i have the same problem... i wonder if its common on this car
my leak is really bad... i can fill it up and it'll be gone within a day
97 Camry: 17" Enkei rims, lowered with Ground Control and tokico,
Alpine head, mids, and highs, rockford 4-channel, 12" P3 rockford,
MTX monoblock, TRD RSB, Clear Corners, 6K Mod Express HID kit
.Camryman97. is offline   Reply With Quote
Old 01-11-2010, 06:33 PM   #4 (permalink)
[g4.Rep]
Gameroom cash: $245932
View ONE_to_HATE's Photo Gallery
that's not a leak, that's a HOLE! LOLz. - you should bust a DIY..
to the OP, there is no easy way to remove it really- i had to forcefully remove mines even when the bolts are already off.. with that said, take out the front bumper and use JB weld- and call it a day!
http://i55.tinypic.com/oa6dj8.jpg
[TRD.jpn][TRD.usa][5Zigen][DDM][DENSO][BC][STICH][FEDERAL][STANCED]
ONE_to_HATE is offline   Reply With Quote
Old 01-11-2010, 06:41 PM   #5 (permalink)
im not to worried about it
but some day if im bored i may fix it just so i can get the light in the dash to turn off
Old 03-17-2010, 11:49 AM   #6 (permalink)
tekno9000's Avatar
View tekno9000's Photo Gallery
I have same issue in my 95 Camry. Anyone found out how to remove the wiper liquid tank?
Found a partial solution. The supply line was getting kinked near the hinge of car hood. Fixed it. See how long it goes.........
Thanks,
Tekno 9000
1995 Camry LE 5SFE 4 Cyl.
tekno9000 is offline   Reply With Quote
