Fresh Mill for the Gen 3 --56K warning - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-12-2010, 07:10 PM   #1 (permalink)
O-Dark-30
frenum49's Avatar
View frenum49's Photo Gallery
Just some pic whoring.
frenum49 is offline   Reply With Quote
Old 01-12-2010, 09:32 PM   #2 (permalink)
95 5S-FE
CROYCE992's Avatar
View CROYCE992's Photo Gallery
lookin real good
4T 6M1 1995 Toyota Camry 5S-FE DX AT Sedan - 171k miles
CROYCE992 is offline   Reply With Quote
Old 01-12-2010, 09:50 PM   #3 (permalink)
asphalt victory's Avatar
View asphalt victory's Photo Gallery
wow the finish work is great! what did you use to get the valve cover that...nice!!!
it looks like some kind of brand new super engine verry classy
MAY AN EMPTY PARTS BOX BE MY WINNING TROPHY
asphalt victory is offline   Reply With Quote
Old 01-12-2010, 10:45 PM   #4 (permalink)
slowamatic noob
a94autoCamry's Avatar
Gameroom cash: $149910
View a94autoCamry's Photo Gallery
^ x2
looks very nice, looks modern
slow white - "no show and no go"
a94autoCamry is offline   Reply With Quote
Old 01-12-2010, 10:57 PM   #5 (permalink)
TOYODA KAMURI
the_professional's Avatar
View the_professional's Photo Gallery
holy shit, that 5SFE looks legit.
really nice work!
i love my 1992 Toyota Camry LE 2.2L 5S-FE - 73K
9005 NIGHT GUIDE LOW BEAMS|FOG LAMPS|PIONEER HU&AUDIO|KEYLESS ENTRY
1995 Acura Legend LS KA7 3.2L C32A - 87K
SADLY, SHE HAS MUCH MORE MODS...
the_professional is offline   Reply With Quote
Old 01-12-2010, 11:03 PM   #6 (permalink)
A camry n00b
peshwa's Avatar
Gameroom cash: $257859
View peshwa's Photo Gallery
3rd Generation Engine porn
This is freaking ENGINE PORN dude ....make love to it! Mmmmmmmuaaaaaaaaahhhhhh
details/background if ya dont mind?
1995 Camry DX L4 178,6XX miles and counting each mile.... acquired 05/25/2007 at 129K miles
2004 Mazda6 I4 5-Speed Manual 115,500 miles acquired 01/21/2011 at 109,XXX miles
peshwa is offline   Reply With Quote
Old 01-12-2010, 11:03 PM   #7 (permalink)
View Kvo_8's Photo Gallery
it looks good man, what all did you do to it?
Kvo_8 is offline   Reply With Quote
Old 01-13-2010, 07:42 AM   #8 (permalink)
O-Dark-30
frenum49's Avatar
hmm
I have been working on this engine a little at a time over the winter. It is much nicer to have it on a stand so I figured I would go balls to the wall and do a full restoration. There is really too much to list but I will try. The bottom end got new crank and rod bearings. All new bottom end seals, rear main, front crank seal, oil pump seals, etc etc. Basically rebuilt the whole bottom end besides rings. I removed the balance shaft assembly and blocked off the oil passage to free up some HP and boost oil pressure. New timing belt kit including tensioner and idler. New frost plugs pounded in. The head went to the shop for milling and crack check and then I spent a number of hours doing a mild port and polish to open up any air flow restrictions. Replaced valve stem seals. New head gasket of course. The alternator was rebuilt with a new reg, the case was blasted and a few parts got fresh paint. All sensors are new, new dist cap and rotor, etc. All small parts were blasted, primed and painted. Basically if it was not new it was primed and painted. This is the third valve cover I have polished. The ridges on the top side were ground flat and the whole thing was hit with scotch-brite pads on an air grinder, several stages of sand paper on a DA, 3 stages of clay bar on the air grinder and finally Mothers mag polish. The intake got the same treatment. I posted a pic below of the engine bay before the restoration just so you can see the polished intake. I will post more pics when I get the intake bolted onto the engine on the stand.
Anyway I am sure ther is more that I am forgetting but you get the point.
Here is a pic before the restoration so you can see what the intake looks like polished.
Old 01-13-2010, 07:21 PM   #9 (permalink)
'95 Camry LE coupe
View MurderedOut's Photo Gallery
Looking reallly good!
MurderedOut is offline   Reply With Quote
Old 01-13-2010, 11:57 PM   #10 (permalink)
TN's bilingual ambassador
View Gerson's Photo Gallery
Very nice, so much time and patience to clean every single detail on that engine, you're such a whore! lol j/k. I need to do that when I rebuild my engine and tranny. I bet ur car is an auto since I see the flexplate (or what most ppl refer to flywheel). Are u keeping the auto tranny or swapping in a 5 speed?
92 ウィンダム (ES300) VCV10L-BTMGKA 3.0L 3VZ-FE w/E53 5 speed
http://www.cardomain.com/ride/3302985
Gerson is offline   Reply With Quote
Old 01-14-2010, 02:37 AM   #11 (permalink)
O-Dark-30
frenum49's Avatar
hmm
I have a 5-speed donor car that I recently found on Craigslist for $450.
Old 01-14-2010, 09:35 AM   #12 (permalink)
95 5S-FE
CROYCE992's Avatar
WOW i really wish i had the time, money, and experience to do everything you did to my 5SFE. seriously, great job
Old 01-14-2010, 07:45 PM   #13 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
now remove the engine and leave it on the stand so it always look that pretty. Just replace it with a card board cutout under the hood.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
