Radio Multiplexing Question
My 2000 Camry LE is currently sporting a JBL system from an XLE of the same year, including the new factory radio and amplifier from that car. The XLE was equipped with two antenna cables going to the rear window. My car only has one. I thought one was for AM and one was for FM. I found out today that they're both for AM/FM, and that it's called multiplexing... where I guess both signals are combined into one better signal? I hope I got that right.
So anyway, when I replaced my carpet several days ago, I already ran both cables under it going to the rear window. At that time I still thought the thinner cable was for AM.
Now to the question. Is it worth getting that second cable hooked up to the rear window? And if so, what type of place does something like that? The guy at the audio shop I went to today explained to me that wasn't two separate antennas but "multiplex." And he said getting that second cable attached will make absolutely no difference. They also do not do that type of work there. So I'm assuming no audio shop does.
2000 Toyota Camry LE (Japan made) i4 5S-FE 367,000+ miles.
