Has anyone ever had an A/C compressor for his Camry replaced? What did it cost? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-13-2010, 05:45 AM   #1 (permalink)
View Mithridates's Photo Gallery
Question Has anyone ever had an A/C compressor for his Camry replaced? What did it cost?
I have a 98 Camry whose compressor has seized. If the work is an arm and a leg, I might end up trying to replace it myself. I do know that a remanufactured compressor and clutch alone is $250.
Mithridates is offline   Reply With Quote
Old 01-13-2010, 06:01 AM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
I'm not sure whether the one on the right (10PA15L w/5groove clutch)
will fit your Camry. http://www.acsource.com/toyota_1.aspx
Good source for A/C parts, etc. as well if you can rebuild. I repaired my Mitsubishi compressor with a new shaft seal for about $20.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 01-13-2010, 01:36 PM   #3 (permalink)
View AlmightyCamry777's Photo Gallery
That's fantastic, i'm amazed you were able to find parts!
THe compressor is bolt and unbolt so you may want to consider changing it yourself. If you have it done the labor won't be cheap. However you will probably have to have it recharged by a shop - (i know they sell those cans of refrigerant at walmart and this would save money if you could use them, but i don't know if they would work for a full recharge.)
AlmightyCamry777 is offline   Reply With Quote
Old 01-13-2010, 02:54 PM   #4 (permalink)
Thanks a bunch for the info.
Old 01-13-2010, 02:56 PM   #5 (permalink)
Thanks, man.
Old 01-13-2010, 09:33 PM   #6 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
Or you can get OEM parts from Aaron at Lithia Toyota for 20% off...
RichieRichJP is offline   Reply With Quote
