1992 camry 4cyl to 6cyl? should I - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-14-2010, 06:46 PM   #1 (permalink)
View scooter23's Photo Gallery
I have two 1992 camry's one is a 4 cyl that sent a rod through the block. The body and interior is in great shape. The other is a 6 cyl that only has 40,000 miles on it. I want to put the 6 into the 4. The biggest challenge look's like it will be changing the computer. Does any one know, do I have to take all the wires running thru the firewall or will the computer plug into the same connections. Any other info would be greatly appreciated.
Thanks
scooter23 is offline   Reply With Quote
Old 01-14-2010, 06:52 PM   #2 (permalink)
View Kenny_McCormic's Photo Gallery
If the 6 has only 40k on it, why bother?
Kenny_McCormic is offline   Reply With Quote
Old 01-14-2010, 07:31 PM   #3 (permalink)
The 6cyl has heavy body damage and the interior is bad.
Old 01-14-2010, 07:38 PM   #4 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
just swap everything. the WHOLE subframe with engine and tranny mounted, brakes, fues boxes(not sure if they differed in 92 between teh 4cyl and V6) and computer. should take a while but pretty much plug and play.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 01-14-2010, 08:34 PM   #5 (permalink)
Just pulled the wiring harness thru the firewall. Looks like it won't be to bad. I think I will be able to pick the engine up with out unhooking any wires from the motor itself. Do the same with the 6 cyl and swap out the computers and hopefully I'll be good to go. Ha, it's never that easy who am I kidding!
Old 01-14-2010, 09:37 PM   #6 (permalink)
rusty9's Avatar
Gameroom cash: $440405
View rusty9's Photo Gallery
lol good luck, you'll need ALL the wiring harness's including the dash, cowl, engine and accessory. the cluster. the master cylinder. and the steering knuckles. and all the power steering lines. and emissions crap. and the radiator with fan.
if you dont mind the work, go for it. although many will suggest just buying a new(used) car
rusty9 is offline   Reply With Quote
