thanks for the link to the
manual
it is the best manual i have used. especially the wiring diagram.
i checked ALL fuses(both boxes and alternator fuse). only 2 fuses were blown. they where fuse #14 dome and #15 ecu-b located under hood. all other fuses were fine.
After looking at the wiring diagram, i figure the issue will most likely be a Fusible Link Block or a Junction Block. I guess i will be getting out the test light and climbing under the dash
to track down the problem with the help of the diagram. Hopefully before my back gives out.
Please keep the ideas coming, just in case there is more wrong than Fusible Link Block or a Junction Block (if that is the problem).
Since everyone has been so willing to help and i have always found helpful info here in the past i will make sure i post the outcome for future.
Once again, thanks for the help!
