Just some quick questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-14-2010, 10:59 PM   #1 (permalink)
Gameroom cash: $125050
View redtigerrocks's Photo Gallery
3rd Generation Just some quick questions
I have a 94 Camry V6 with around 170k miles and I just had some questions about minor issues:
-Ive been recently having some wobbling in the steering wheel at low speeds (under 35-40 MPH) and my service place said i had choppy tires. is choppy tires uneven wear of the tires?
-My tires currently have 5/32 left on the treads and I know I probably should change them around 3/32 or else it wont pass state inspection. Does anyone know , speaking with mostly city driving and occasional once a week highway driving, how many more miles my tires will last? I've put around 20k miles on them.
-Service guy told me my valve cover gasket was leaking oil but ive been checking my oil often and haven't seen a drop in oil level. Should I be concerned still?
redtigerrocks is offline   Reply With Quote
Old 01-15-2010, 12:17 AM   #2 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
If your shop is telling you the tires are "choppy", you may want to look at getting service at another shop. Thats a very poor term only the shop should attempt to define. Honestly, choppy? Sounds like he spent too much time on the high seas. Cupped and/or uneven tire wear is usually related to either lack of tire rotation or bad suspension parts/alignment. Get new tires ASAP. 1/8" isn't much and your wet road handling is probably suffering at this point.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
Old 01-15-2010, 12:19 AM   #3 (permalink)
stingraycamry1996's Avatar
View stingraycamry1996's Photo Gallery
3rd Generation
Hi redtigerrocks
i'm no pro this is just my opinion here.
i think by choppy tires he means you have a tire with a broken steel belt which causes the tire to deform and not be perfectly round making you car vibrate. seeing as their's not much life left on these tires i'd get 4 new ones plus when installing tires they have to balance them so if the vibration was coming from an unbalanced rim you'd have it solved.
as for the valve cover leaking, if the oil level is not dropping i wouldn't touch it but definetly check your oil level once a week or so.
1996 Camry DX 2.2L 280 000 km ....SOLD
2002 Camry LE 2.4L 109 000 km ....Running strong
stingraycamry1996 is offline   Reply With Quote
Old 01-15-2010, 01:29 AM   #4 (permalink)
Chemist at Chevron
Gameroom cash: $314885
View bdy0003's Photo Gallery
You may have uneven tires; if your fingers brush up on the treds, its not always even. I had this happen to my car. While I didnt really have whobbling, you could hear pulsations/vibrations from speeds 25mph-55mph, and then the frequency became too fast for me to pick up. Changing the tires made the difference and while you're at it, you might want to change your struts as they can cause this tire damage.
As for your valve cover gasket, change it anyways. You can probably do it in under an hour with no problems.
95 Camry LE I4 195k
bdy0003 is online now   Reply With Quote
