Good to seafoam or not? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-15-2010, 02:46 PM   #1 (permalink)
Chemist at Chevron
Gameroom cash: $314885
View bdy0003's Photo Gallery
I have an oil leak around the timing belt area. Right now, I use high mileage oil so the leak could be worse. I plan to seafoam only the vacuum lines. Anybody know if its safe to do so even though I have the leak?
BTW, my valve cover gasket and dist o-ring were replaced recently.
95 Camry LE I4 195k
bdy0003 is online now   Reply With Quote
Old 01-15-2010, 03:13 PM   #2 (permalink)
View SirThomas88's Photo Gallery
I can't imagine why inserting SeaFoam into the vacuum lines would impact your oil leak or vice versa.
But I'm no expert. I would still do it.
SirThomas88 is offline   Reply With Quote
Old 01-16-2010, 05:11 PM   #3 (permalink)
View LUVLEXUS101's Photo Gallery
I seafoamed today, I felt like the car was pulling a lot harder but when I was adding the seafoam, smoke starting coming out the engine, it looked like it was coming from the front exhaust manifold but I'm not sure.
Any ideas anyone?
LUVLEXUS101 is offline   Reply With Quote
Old 01-16-2010, 05:56 PM   #4 (permalink)
Slowly learning....
View Retrospekt's Photo Gallery
Any ideas anyone?
You have a leak in your flange gasket between the headers and front pipe.
1996 Toyota Camry | 4 Cyl. 2.2L | Black Paint with Tan Interior | All Stock | DEAD at 155k. Broken Crankshaft/Main Bearing
Retrospekt is offline   Reply With Quote
Old 01-16-2010, 05:58 PM   #5 (permalink)
Easy to fix? Is it as simple as getting a new gasket and putting it in?
Old 01-16-2010, 06:34 PM   #6 (permalink)
Chemist at Chevron
Arent those gaskgets made out of metal?
95 Camry LE I4 195k
Old 01-16-2010, 06:37 PM   #7 (permalink)
Slowly learning....
They are metallic wrapped in hard rubber. It's an easy replacement given you have the right tools. It's a tight fit to get the 3 bolts off, and bet your ass they'll be rusted.
Old 01-16-2010, 07:25 PM   #8 (permalink)
Chemist at Chevron
Yeah, well being in Queens or Chicago, I'll bet the weather and salt does that to you.
95 Camry LE I4 195k
Old 01-16-2010, 09:41 PM   #9 (permalink)
Is this possibly a reason why I get horrible has mileage?...like 13 mpg
Old 01-17-2010, 04:49 PM   #10 (permalink)
View CCMphysician's Photo Gallery
I'd be willing to bet you also have pretty poor compression. Did the Seafoam help at all with sluggish acceleration, etc? Also, keep track of your gas mileage. I'd be willing to bet that it dropped another 1-2 mpg after the Seafoam treatment.
On another note, are you losing oil? If so, at what rate?
-CCM
CCMphysician is offline   Reply With Quote
Old 01-17-2010, 04:52 PM   #11 (permalink)
I'm not losing oil but the Seafoam did really help with the acceleration. The car was very peppy right off the line spinning the tires and everything. At one point my fuel economy was down to something like 9 mpg all city driving.
Old 01-17-2010, 06:56 PM   #12 (permalink)
Chemist at Chevron
Why does Seafoam drop the fuel efficiency by 1-2mpg?
-CCM
95 Camry LE I4 195k
Old 01-17-2010, 09:03 PM   #13 (permalink)
Normally it shouldn't and in almost all vehicles it won't, but in some vehicles (very rarely and in very worn and poorly maintained engines), the carbon deposits are actually aiding the seals. Seafoam removes those carbon deposits. Again, that would be very rare.
-CCM
Old 01-17-2010, 09:04 PM   #14 (permalink)
Was this before or after the Seafoam treatment? What other maintenance have you done on this vehicle?
-CCM
Old 01-17-2010, 09:15 PM   #15 (permalink)
Oil changes every 3 months, with Pennzoil and mostly Toyota filters, occasionally a Purolator filter. Changed the tranny fluid last summer, head gasket was changed before, as well as the pwr steering pump.
