Heater problems 2001 camry
Hi,
I have a 2001 camry CSi with manual dial selector for the heating/ cooling, fan control/ vent selection.
My problem is that the heat selector has become stuck.( i manually disconected cable for heating coil in engine compartment and closed the valve. the dial was still stuck) I also noticed the the panel does not light up at night.
2 questions.
Any suggestion on how to fix the stuck dial.
Does the panel light up at night and can I replace the bulb? All fuses are intact.
THanks
Reason: Bad typing!
