changing distributor o-ring - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-15-2010, 10:34 PM   #1 (permalink)
View cj0609's Photo Gallery
After changing ignition coil someone mentioned to change the o-ring on the dis. I picked up an o-ring from the dealer with a gasket for the dis cap. When I had the dis out i could see a ring on the shaft of the dis, I assume this is it. The o-ring is hard to get off. If I have to snip it ,I will. I am more concerned with putting the new one on. Do i have to take off any part of the shaft or do i just slide it on. I know it sounds like a silly question, i want to do this once so i can get this thing back together. Thanks.
cj0609 is offline   Reply With Quote
Old 01-15-2010, 10:36 PM   #2 (permalink)
Failed to mention, i have a 92 2.2.
Old 01-15-2010, 11:25 PM   #3 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Good chance you'll have to cut the old o-ring off -- it's going to be brittle and inflexible. Old one should have no trouble stretching over the end of the dizzy shaft to get to the slot on the housing. A light coating of engine oil on the new seal will make pushing it up there a mite easier, and will also help things seal up when to put 'er back together.
Old 01-16-2010, 03:24 AM   #4 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
If your having a hard time with the old o-ring, get a small nail. Lightly tap the nail into the o-ring until it splits. Then it will be much easier to remove.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
Old 01-16-2010, 07:44 AM   #5 (permalink)
View flyeri's Photo Gallery
Easy to reinstall with a little oil or grease. Good time to buy or borrow a timing light if you don't have one.
flyeri is offline   Reply With Quote
