HELP! air fuel ratio - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-16-2010, 10:16 PM   #1 (permalink)
Registered User
View Timsy's Photo Gallery
i need help
where is the air fuel ratio sensor located on a 2000 camry 4cyl?
thanks
Timsy is offline   Reply With Quote
Old 01-16-2010, 10:37 PM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Start at the radiator cap, and head straight back to the engine. You'll hit a big silverish metal shield that is the heat sheld for the exhaust manifold. Slide down to the bottom of that shield, and there should be a fairly large sensor sticking out of the exhaust pipe -- that's the A/F sensor.
There's also another oxygen sensor (not an A/F sensor) under the car attached to the exhaust pipe behind the catalytic converter. It's mainly just to monitor the efficiency of the cat, 'tho -- the up-front A/F sensor is the primary sensor for trimming the A/F mix.
Old 01-16-2010, 10:42 PM   #3 (permalink)
Registered User
Japan
thanks for your help. ninja wrench!!
Old 01-17-2010, 10:43 AM   #4 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
STICKING THROUGH THE HOLE IN THE HEAT SHIELD.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
