Valve Cover Washer Mod. How Tight?
I am replacing the valve cover seal and found the washer mod.(where you add two washers to the valve cover bolt) What do I torque the bolts down to? 96 1MZ-FE.
I found 69 in/lbs for stock set up and wounder if with the washer mod, I would need more or less torque?
WHen I torque the bolts without the washer mod, the bolt bottoms out. With two washers and torquing to 69 in/lbs,
the gasket is squished down and the gap between the cover and head is half of what it is with out the washers.
94 Land Cruiser 374,000 mi
96 Camry 1MZ-FE 230,000 mi
