damn you rust hole in fuel tank! anyone have a patch suggestion? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-18-2010, 11:49 AM   #1 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
two weeks ago i finally replaced the filler neck on the 96 camry. after much cursing and a couple of sheared bolts later the old part was off and the new one installed. yesterday i filled the tank full. as i was removing the pump handle at the station there was a strong odor of fuel followed by a small gas stream coming out from under the car. last night discovered where the vent tube connects to the fuel tank, there is a 1/4" rust hole in the weld.
question to all of you - in my rummage through the garage to figure out a patch, i decided to use some JB weld (as opposed to high temp RTV or other epoxies/sealers) - will gasolene disolve JB Weld? is there something else to consider or should i be shopping for a new tank?
being that i have a backup vehicle if really needed, i am also considering dropping the tank, draining the fuel, airing out the tank and possibly welding it. anyone have experience welding a fuel tank?
i drove the camry today but cant tell if its leaking or not. everything is either wet from the roads, metling snow or condensation.
ghettosled is online now   Reply With Quote
Old 01-18-2010, 12:49 PM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862710
View BamZipPow's Photo Gallery
JB-Stick is what you probably want to use then...
Have you thought about using a gas tank sealer? POR-15 makes one that is second to none.
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is offline   Reply With Quote
Old 01-18-2010, 02:05 PM   #3 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
Duct tape.
Chris Crash is offline   Reply With Quote
Old 01-18-2010, 07:31 PM   #4 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
if its a whole caused by rust the only good solution is replacement. if it is leaking even slightly(sweating) that mean rust is exposed to the gas and not only will the gas speed up break down of the metal but it will put minerals in the fuel you dont want. Id find a replacement asap.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 01-18-2010, 08:21 PM   #5 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
flood the tank with argon before you weld, or else, kaboooom
^ and leaving it that way!
Old 01-18-2010, 09:11 PM   #6 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Fuel leak is dangerous. REPLACEMENT would be the proper fix. However, you can temporarily patch it up using Permatex Instant Gas Tank Repair compound:
http://www.permatex.com/products/Aut...ank_Repair.htm
A new tank online is about $188 + shipping:
http://www.rockauto.com/catalog/moreinfo.php?pk=534579
Or you can get the EBay one for $150 shipped.
Old 01-18-2010, 09:27 PM   #7 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $609731
View Zembonez's Photo Gallery
There is no FIX for a rusted out fuel tank. If it's rusted through in one spot, it's paper thin in many others. Replace it and be safe!
Zembonez is offline   Reply With Quote
Old 01-19-2010, 01:06 PM   #8 (permalink)
ghettosled's Avatar
thank you all for the suggestions and tips. i think i will get a replacement tank. i dont feel safe carting around my kids in a potentially un-safe vehicle. i will probably scour the local salvage yards for a uesd replacement before ordering new. feels like im rebuilding the camry one piece at a time.
does/did anyone else have their tank rust though? havent heard of this from anyone with a camry.
Old 01-19-2010, 01:17 PM   #9 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Hmmm and i always thought these had plastic tanks. Im gonna check my 98 next time i have it up in the air.
carsrus is offline   Reply With Quote
Old 01-19-2010, 07:35 PM   #10 (permalink)
View Kenny_McCormic's Photo Gallery
After flooding it, sand down and solder in a patch.
Kenny_McCormic is offline   Reply With Quote
Old 01-19-2010, 09:45 PM   #11 (permalink)
96 3MZ M/T
chronoti's Avatar
you pull it yards punch the tanks with a brass punch to dump the fluid to make it enviro safe?
not sure 100% but if so
http://www.car-part.com
Old 01-20-2010, 02:51 PM   #12 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
I have brazed steel gas tanks with brass filler. Removed fuel and fuel sender, filled tank with water.
Beware that Rustproofing or undercoating smokes alot if it catches fire.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
