Brake Bias? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-19-2010, 12:02 PM   #1 (permalink)
95 5S-FE
CROYCE992's Avatar
View CROYCE992's Photo Gallery
Brake Bias?
I have noticed that under heavy breaking my car fishtails to the left every single time. Under normal breaking, it is not noticeable at all. It is just when I have to break hard to avoid the casual "new driver" who fails to look before exiting a driveway or decides to jump in front of me of cut me off that my car brakes but the rear fishtails always to the right.
What's wrong with my car? It is time to do maintenance on my drums and I need new pads but I am thinking that this is related to something else. I could perhaps get it checked out when I have the maintenance done.
4T 6M1 1995 Toyota Camry 5S-FE DX AT Sedan - 171k miles
CROYCE992 is offline   Reply With Quote
Old 01-19-2010, 02:09 PM   #2 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
Are your rear wheels locking up when under heavy braking? To fishtail, I'd think you'd have to lock the wheels up unless you've got a tire thats really low on air pressure. Any tire screeching or skidding? Just trying to clarify your symptoms here.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
The Following User Says Thank You to 96paseo For This Useful Post:
CROYCE992 (01-20-2010)
Old 01-19-2010, 02:25 PM   #3 (permalink)
95 5S-FE
CROYCE992's Avatar
I am not sure whether or not the wheels are locking up or not. I have my stock steel wheels on for the winter and after putting them on I had them all torqued and the proper psi of air put in at the local Discount Tire. There was one circumstance when the roads were dry and I had to brake hard after putting on my steel wheels and it fishtailed to the right. It has never to the left ever. The same thing happens during the summer when I have my summer set on too.
edit: off topic but how is that Rtech voltage stabilizer working out for you?
Old 01-19-2010, 03:01 PM   #4 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
All things being equal (after inspection of the brake lining materials, pistons, calipers, hardware ect at all four coners), I'd have the brakes bled to remove air bubbles and moisture accumulation. Should be done to remove moisture and contaminants every 24 months unless you like to buy brake parts.
A bubble in a line could reduce pressure and cause this type of issue.
Also check all for strut dampners. A bad shock/strut can make a corner dive, the other side lift and whosshhhhhhh out of control. . . .
Edit: a weak or saging spring would not be helpful either during max braking effort.
73sport is offline   Reply With Quote
The Following User Says Thank You to 73sport For This Useful Post:
Old 01-19-2010, 05:08 PM   #5 (permalink)
Gameroom cash: $303255
Just a hunch here. It can also be contamination on the left rear brake shoes/drum. Remove the left rear wheel and drum and check for a leaking wheel cylidner that is leaking brake fluid on to the shoes. This would make the right rear drum brake apply a lot more braking force on that wheel, causing the rear of the car to fishtail to the right.
Mike
The Following User Says Thank You to Mike Gerber For This Useful Post:
Old 01-19-2010, 07:37 PM   #6 (permalink)
View Kenny_McCormic's Photo Gallery
The car goes right because the road grade goes that way.
Kenny_McCormic is offline   Reply With Quote
Old 01-19-2010, 09:41 PM   #7 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
I'd bleed the system first. Also clean/lube and inspect the calipers/drums, rubber brake hoses.
The Following User Says Thank You to JohnGD For This Useful Post:
