Escort Passport X50 8500 Hardwire Location - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-19-2010, 12:19 PM   #1 (permalink)
95 5S-FE
CROYCE992's Avatar
View CROYCE992's Photo Gallery
Nearly every car forum has a hardwire tutorial for their radar detectors. I want to write one up with full pictures because as of now I have the radar detector and the smartcord hardwire kit and some easy acces fuses for power. My plan however is to mount the buttons to the smartcord somewhere in the interior of my car.
Do you guys have any suggestions?
As of now I wanted to do to the right of the U trim ring around the stereo. There seems to be just enough space behind it to place the electronics board for card:
Pictures courtesy of ASG14's DIY: Gen 3 "D" Bulb replacement
I also really wanted to underneath the ECT button but it doesn't seem like there is enough room for the electronics board.
Picture courtesy of dz63's DIY: GEN3 2.2L Parking Brake Cable Replacement Procedure
This link will show you how the electronics board looks like: http://www.audiworld.com/tech/elec102.shtml
[IMG]file:///Users/labuser/Library/Caches/TemporaryItems/moz-screenshot.png[/IMG]
4T 6M1 1995 Toyota Camry 5S-FE DX AT Sedan - 171k miles
CROYCE992 is offline   Reply With Quote
Old 01-19-2010, 12:39 PM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
I'd think it would look cleaner just to the left of the stereo head unit. Good location so you don't have to glance down too far when it goes off, and easy power routing. FWIW, please do a better job of splicing into the power than the hack that you linked to.
Or, you could use this as an opportunity to upgrade to a single-DIN head unit (unless you just gotta have cassette tape capability), get a plate for the area below the head unit, and place your circuit board behind that.
Old 01-19-2010, 03:01 PM   #3 (permalink)
95 5S-FE
CROYCE992's Avatar
true. after looking at the picture some more, It would not only be more convenient to have the buttons placed there but there would be wayy more room behind it to create a makeshift mount for it all. btw that is not my car's interior. I borrowed those pictures from other DIYs since I am away from home. I am in the middle of an audio upgrade actually and decided to hardwire while the trim panel is off instead of procrastinating any further.
Old 02-09-2010, 12:42 AM   #4 (permalink)
'_'
Touge Star
'_''s Avatar
Gameroom cash: $421512
iTrader Score: 10 reviews
View '_''s Photo Gallery
Just wondering if you ended up doing the hardwire install and/or figured out a place to put the buttons/lights. I'm asking because I recently picked up an 8500 x50 for $130 and want to have a cleaner install as well. Also, is there a way to find out the software version of it if there's no serial number?
山道だいすきです。
http://www.cardomain.com/ride/2538603
'_' is offline   Reply With Quote
Old 02-09-2010, 12:52 AM   #5 (permalink)
95 5S-FE
CROYCE992's Avatar
I have all the parts ready: radar detector, hardwire Smartcord, and Access a Fuses. I'm pretty set on the left side of the stereo U-ring as it has the more space behind it than the right for some sort of custom housing for the electronics board for the Smartcord. Right now I am just trying to figure out how to wire a manual antenna from the A pillar to the stereo. My original one was eaten up a few years back at a cheap car wash. As soon as I figure out how Toyota wired it, I will be replacing the antenna to a new one, upgrading the stereo, and hardwiring the Escort X50 8500 and writing a DIY.
Old 02-09-2010, 07:14 AM   #6 (permalink)
TN's Mad Chemist
projektvertx's Avatar
Gameroom cash: $568401
iTrader Score: 20 reviews
View projektvertx's Photo Gallery
I actually helped my friend hardwire his V1 radar detector into the car. You can hardwire it into the driver kickpanel fusebox and run the wire up to the top of the windshield. Use an add-a circuit from Radio Shack, O'Reilly's or Autozone. I assume you are already a member of radardetector.net??
1995 Toyota Camry V6 LE-6M1 250K Miles, Fun Car
1997 Acura RL-Gone
2007 Acura RL SH-AWD, Technology Package, Opulent Blue Pearl- Fun Car/Daily Driver
projektvertx is offline   Reply With Quote
Old 02-09-2010, 11:06 AM   #7 (permalink)
'_'
Touge Star
'_''s Avatar
I might try and hardwire it today. Only problem is, I haven't found a good location for the mute button/led panel yet.
山道だいすきです。
Old 02-09-2010, 11:18 AM   #8 (permalink)
95 5S-FE
CROYCE992's Avatar
ads
nop, not a member.. any benefits to being one?
I was in the same boat for the longest time. Only with in the last few weeks do I feel good about my location with the u ring. If it helps, the sticker that surrounds the mute button/led panel which you are going to have to peel off and cover up the location of your choice is black. perhaps if you like a sort of blended look you could find a black trim piece or panel as the location. also you need a little bit of space behind the location to hide the board.
Old 02-09-2010, 12:08 PM   #9 (permalink)
'_'
Touge Star
'_''s Avatar
Yeah I wanted to do that but all my black panels by the steering wheel are taken up (side mirror control, factory alarm, and a fog light switch I added). I do have an aftermarket alarm now, so maybe I'll pop the factory alarm panel out and dremel the plain one.
山道だいすきです。
Old 02-09-2010, 04:56 PM   #10 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Hell. I'd clear out a space next to the hazard switch...or somewhere in that area.
'07 Honda Ruckus Big Bore
Old 02-09-2010, 09:53 PM   #11 (permalink)
'_'
Touge Star
'_''s Avatar
I just finished hardwiring it! Still need to find a good spot to mount the button and lights. They're currently sitting on top of the steering wheel column :/
山道だいすきです。
