1997 toyota camry. how do i reset or disconnect the factory alarm - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-19-2010, 12:51 PM   #1 (permalink)
View jimstewa1's Photo Gallery
im having problems with the factory alarm, it started yesterday a steady buzz or beep from under the hood then when im driving the horn will just go off and not shut off. until i pull over turn the car off and disconnect battery. and then happens again a little later .
jimstewa1 is offline   Reply With Quote
Old 01-19-2010, 03:24 PM   #2 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
Under the drivers side dash board, pretty much directly behind the fuse panel, you'll see a lot of wire that seem out of place and a black box zip tied up there. There's a huge white connector going into the black box. Just pull it out. That's it.
If you can't get it out, cut the zip ties that hold the black box in place, that way you have a little more wiggle room.
Chris Crash is offline   Reply With Quote
Old 01-20-2010, 01:39 AM   #3 (permalink)
right on thanks, is there just a way to reset it??
Old 01-20-2010, 01:17 PM   #4 (permalink)
To reset it, you can probably just unhook the battery for like 10 seconds. Or just unplug the module like I said for a few minutes.
Old 01-20-2010, 02:43 PM   #5 (permalink)
ok ill try unhooking the unit, unhooking the battery doesnt do anything except disable the horn when it decides to go off thanks ill let u know the results.
Old 11-06-2010, 05:20 PM   #6 (permalink)
update
When i was having problems with My alarm, i figured out after i stripped out the terminal connector that goes on the battery that a poor connection and corrosion were causing all the alarm problems.
A simple fix that caused alot of headaches
