Trans question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-19-2010, 03:28 PM   #1 (permalink)
View charlie98camry's Photo Gallery
Trans question
I have a 98 Camry 260,000 miles. The car has been parked for 10 mo's.
I was told I may have a problem with the trans seal being dried out.
Does anyone know if this is correct. Also is there anything else I need
to worry about or fix B4 I try to crank the car?
Thanks
charlie98camry is offline   Reply With Quote
Old 01-19-2010, 03:43 PM   #2 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
Of course it's possible, if so you'll have to replace it.
If you crank it and it leaks, you'll still have to replace it.
I would just go ahead and drive it. This way you know what works/leaks and what doesnt and you can fix it.
Chris Crash is offline   Reply With Quote
Old 01-19-2010, 04:32 PM   #3 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
put a little oil in the VC port before cranking, that will lube stuff a little better before the initial start, then give it a couple cranks before really starting it so it throw some oil around.
the seal will leak if dry, theres nothing you can do but replace it if it does so judt give it a shot.
<<<<off topic but WTF is that
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 01-20-2010, 12:38 AM   #4 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
What ever you do never add products that imply they'll stop a trans leak as fix for anything.
It'll only leak worse later.
73sport is offline   Reply With Quote
