Trouble shooting, -dies when first started - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-20-2010, 10:53 AM   #1 (permalink)
View Judge2's Photo Gallery
Hi, Im looking for some diagnostic or troubleshooting advice. On the 94 LE, recently, (maybe because its colder?) the engine will start, but stall unless it is given some gas for the first 30 seconds or so.
Judge2 is offline   Reply With Quote
Old 01-20-2010, 11:19 AM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Since the duration is so short, best guess would be a sticky IAC. Have you cleaned the throttle body recently?
Good DIY at How to: Cleaning Throttle Body -4 Cylinder Engines- With Pictures
The Following User Says Thank You to hill8570 For This Useful Post:
Judge2 (01-22-2010)
Old 01-20-2010, 12:43 PM   #3 (permalink)
Thanks,
Thanks, based on your advice, I just cleaned the throttle body, and followed the directions for cleaning the idle air control (IAC) valve.
I found the youtube video referenced in post two of this thread to be helpful.
I am letting it soak in seafoam clean now.
Old 01-20-2010, 01:44 PM   #4 (permalink)
View _Alex_'s Photo Gallery
I need to do this on my '98 XLE. From time to time, it will start up and just die unless i have my foot on the gas a little. Never does it from a cold start though (Im guessing b/c the RPM is so high) it typically does it after the engine has warmed up and i stop to go into the store or somethin and when I come back, i get this problem. I hope the cleaning fixes this...
_Alex_ is offline   Reply With Quote
Old 01-20-2010, 02:36 PM   #5 (permalink)
Gameroom cash: $303255
A dirty idle air control valve is the most likley cause. Refer to the same thread on cleaning the throttle body and idle air control valve tht hill85780 referenced.
Mike
The Following User Says Thank You to Mike Gerber For This Useful Post:
Judge2 (01-22-2010)
Old 01-21-2010, 08:02 AM   #6 (permalink)
Mike
Yah I read that (well, the one for the V6) I did it last night though, there was def some crap down in the little rectangle hole. Cleaned it all up and started it up and let it run for like 3 minutes. It started up fine this morning (but it always does) so I guess the test will be when I go home for lunch and need to start it warm.
Old 01-22-2010, 08:02 AM   #7 (permalink)
Looks like it worked. I gave it a warm start today, fired right up, no foot on the gas. I changed the air filter too.... that def helped. Mine was grimey, had a pile of leaves in the airbox. Vacuumed that all out, hopefully i wont be having any problems in the near future.
