What is this stuff? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-21-2010, 08:18 PM   #1 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
What is this stuff?
Hey guys,
Almost have all the kinks worked out on my swap here. But one problem. The tranny seal has been leaking and the drivers side axle is like...sticking out a little bit. I'm fixing that tomorrow.
But anyway, I kept checking the fluid level in the tranny relatively often while I was at school the past two weeks, and somehow it never got too low even though there were huge puddles of the fluid under the car.
Today I checked it again before I came home, opened the fill plug and this came pouring out:
Sorry for the shitty quality but my cell phone is all I had. It was kind of like milky coffee, but really thick. Two days ago when I checked, it looked like normal gear oil. Does anyone know what the hell happened?
Chris Crash is offline   Reply With Quote
Old 01-21-2010, 08:38 PM   #2 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Water ingress from the tranny cooler?
Any tranny fluid floating around in the radiator?
Gah...nevermind -- you're running a M/T now, ain't ya?
Still looks like the milkshake you get when mixing water with oil, but damned if I know where you'd get the ingress on an M/T...
Old 01-21-2010, 09:52 PM   #3 (permalink)
Think it could be water?
Yeah it's manual, so, no coolers or coolant anywhere near there.
But after checking it on Tuesday when it still looked normal, I didn't really put the plug all the way in. Maybe half in? I just didn't want to tighten it up because it sure is a bitch to get out. It did rain in Charlotte pretty heavily last night/today so it's not like there wasn't water available.
I really hope that's the case that my own stupidity just got some water in there and I can drain and fill it and problem solved.
Maybe tomorrow I'll pour some water and gear oil in a cup and see if they make that looking stuff.
Old 01-21-2010, 11:09 PM   #4 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
water + oil = milk
well when you do your test the oil going to float on top, make sure you get something to mix it good (like a few gears flying around at a few thousand rpm's) just think of salad dressing
^ and leaving it that way!
Old 01-21-2010, 11:29 PM   #5 (permalink)
Born to Drive
EEngineer's Avatar
Gameroom cash: $426353
View EEngineer's Photo Gallery
yep...that's water + oil
just flush out the gear oil and put back in fresh oil
i'm rocking a bad tranny seal as well.....dripping slowly :p it sux ass, but too much pain to fix it
My Once Beloved Camry
Rest in Peace
NEW ES300 5SPD SUPERCHARGED BUILD THREAD
EEngineer is offline   Reply With Quote
Old 01-21-2010, 11:45 PM   #6 (permalink)
The seal isn't a big concern, I think the axle being partly out is the main leak problem. I don't know about on the gen 3 but on the gen 4, you don't have to take the axle out of the hub to replace the seal! You can just take the brakes off, separate the hub from the control arm and pull it out of the transmission all at once. That might help you fix your seal, unless you have to fix the passenger side, in which case...I send you my condolences. haha
Is the transfer case and transmission connected, i.e., when I open the drain plug on the tranny, that gets the fluid out of the t-case too, right?
Originally Posted by chronoti View Post
water + oil = milk
Yeah after I replied I was thinking about how water and oil won't mix very well...
But I guess the gears would sure mix it up! I had checked it right after driving to a flat spot, so that is very plausible.
Old 01-21-2010, 11:49 PM   #7 (permalink)
Born to Drive
EEngineer's Avatar
yep....passenger side....=[
drain plug drains everything i think
Rest in Peace
Old 01-21-2010, 11:58 PM   #8 (permalink)
Damn that sucks dude. It took me, seriously, about 2 hours to get that clip back in when I installed the manual axles. Maybe I just didn't have the right tools or know how to get it, but that angle you have to be at from below is a bitch.
I just took the smallest vise grips I had, opened them as wide as possible. Got them on the clip, tightened them as much as i could. Then I used my fingers (poor choice, use a screwdriver next time!) to push/hold it in place and release the vise grips. If you use your fingers, it will pinch them in there. And that just...well that just sucks.
Old 01-23-2010, 04:58 PM   #9 (permalink)
Does anyone know what this seal is called? I checked 1sttoyotaparts.com and it had nothing. I don't want to order the wrong thing.
It's the drivers side axle seal, I guess. But my manual doesn't give it a name or a part number, it just says "seal"
