Hey there, this is like the 3rd part of a long string of questions i've had since im finally serious about installing the TRD s/c. I believe this would be it too :p.
Anyways, I see 'jim's fuel mod' on a few different mod lists, i've heard/sort of understand what it does, my question is, is the mod a line that you can buy? or do you have to but a bit of hose and split it yourself?
About the knock sensors, I was looking at Eye8's tutorial for the gen 3, and he slightly mentioned that it was easier on the later 1mz's like in the gen 4's. He said that there was some sort of bracket that you could mount it too that goes like right under the valve cover...if something like that exists, where would I get it, and if it doesn't how and where should I relocate the knock sensors too.
I'm also getting a 255lph fuel pump, is a SAFC 2 req'd?
I found some used injectors for pretty cheap:
http://cgi.ebay.com/ebaymotors/2JZGE...Q5fAccessories
If these will work in my car, then i'll get them, but i dont know if they would. So if anyone can check this out, I'd really appreciate it.
Thank you
