burning oil smell?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2010, 01:43 PM   #1 (permalink)
sexy, dirty, and slow...
93XLEcamry's Avatar
View 93XLEcamry's Photo Gallery
3rd Generation burning oil smell??
i have the 93 3vzfe engine on my camry, and i every time i go up a hill i would smell burnt oil....it is just mine car or has anyone have this experience with their 3vzfe too...
and should i check for leakage??...if there are leaks, how should i go about fixing this leak??
93XLEcamry is offline   Reply With Quote
Old 01-22-2010, 01:56 PM   #2 (permalink)
View WISHYWASHY's Photo Gallery
3vzfe is the V6 right? I have a 94' V6 and the only time I smell something burning is when after an oil change if I spill some on the side
did you recently change oil and made a mess inside?
WISHYWASHY is offline   Reply With Quote
Old 01-22-2010, 03:56 PM   #3 (permalink)
Gameroom cash: $302547
View ricamryman's Photo Gallery
Your rear valve cover is probably leaking into your exhaust manifold... Hence the burning oil smell! My dealer just changed out my valve cover gaskets for approx. $360.00! They said she was very clean inside!....Check your rear valve cover for leaks....
ricamryman is offline   Reply With Quote
Old 01-26-2010, 06:37 PM   #4 (permalink)
The-Camry-Guy's Avatar
View The-Camry-Guy's Photo Gallery
iv got a 94 camry 3vz-fe and i get this smell after long drives quite frequently. im not sure what it is but i think it might be oil. it can get really bad sometimes. im not sure where my leak is. iv been trying to find a fix also.
u should check ur oil level. mine used to go down a bit, but i recently did an oil change and has been topped pretty good since.
The-Camry-Guy is offline   Reply With Quote
Old 01-26-2010, 09:15 PM   #5 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Check the back side of the engine (near the firewall) with a mirror and flash light. See if oil is leaking down from the valve cover gasket area down.
Old 01-26-2010, 11:06 PM   #6 (permalink)
93XLEcamry's Avatar
it is okay if i just keep driving like this???....again it only smells when im going up a hill...
Old 01-27-2010, 05:16 AM   #7 (permalink)
well im not really sure about that. u should get an opinion from someone else. however my car smells ocasionally nowadays (it used to smell more often) so i left it. however if u got big major leaks it might be really damaging to ur car.
if someone else could give advice that would be good.
Old 01-27-2010, 07:51 AM   #8 (permalink)
Gameroom cash: $167485
iTrader Score: 6 reviews
View haux's Photo Gallery
I think that depends on how long you intend on keeping your car. If you'd like to keep it running well for years to come, it's always best to address each and every "problem" as it comes up. If you seriously intend on dumping the car a year from now, you could probably leave it alone. I'm sure my valve cover gasket has been leaking for years and I didn't fix it until just a couple months ago (I4).
2000 Toyota Camry LE (Japan made) i4 5S-FE 367,000+ miles.
haux is offline   Reply With Quote
Old 01-27-2010, 03:14 PM   #9 (permalink)
Just fix the valve cover gaskets & you will be just fine!
Old 05-23-2010, 11:06 AM   #10 (permalink)
View 300K+'s Photo Gallery
Similar problem
I've got an oil leak on my 4cyl 97 camry that seems to be coming from high on the back side (near firewall) of the engine. It is leaking down onto the exhaust pipe and causing noticable smoke when the car is at rest or sitting at a light. I replaced the valve cover gasket and it did not correct the leak. Anyone have any ideas on where the leak could be coming from?
300K+ is offline   Reply With Quote
Old 05-23-2010, 11:30 AM   #11 (permalink)
TN's Mad Chemist
projektvertx's Avatar
Gameroom cash: $568401
iTrader Score: 20 reviews
View projektvertx's Photo Gallery
^ and good on ya using the search function I think what may have happened is the gasket may not be seated properly? Just a theory Seems like it could very well happen with the rear valve cover on a V6, 1MZ or 3VZ, which is what I assume you have?
Bump, maybe someone has a better explanation
EDIT: woops, just noticed you have a 4 cyl. I guess my explanation may not be as plausible as I thought, but I would check anyways...
1995 Toyota Camry V6 LE-6M1 250K Miles, Fun Car
1997 Acura RL-Gone
2007 Acura RL SH-AWD, Technology Package, Opulent Blue Pearl- Fun Car/Daily Driver
projektvertx is offline   Reply With Quote
Old 05-24-2010, 03:16 AM   #12 (permalink)
i poked around under my hood and found a puddle of oil under the distributor. where can this be coming from and can this cause the burnhing smell?
iv got a 3VZ-FE btw.
thanx
Old 05-24-2010, 02:03 PM   #13 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $349653
View BMR's Photo Gallery
thanx
Most likely its the distributor o-ring. It's a pretty easy fix; part is a few dollars. And yes, that can cause the burning oil smell.
You might also take a look at the back-side of the engine block. Another common source of the burning oil smell is the valve cover gasket leaking oil and dripping down onto the exhaust pipe.
BMR is online now   Reply With Quote
Old 05-25-2010, 01:38 AM   #14 (permalink)
thanks for replying. when replacing the distributor o ring, if i twist it accidentally will it screw up the timing?
also will i be able to get to it easily? iv got a 3vz-fe V6, its pretty tightly packed.
where is the vavle cover gasket? what does it look like?
thanks
Old 05-25-2010, 08:27 AM   #15 (permalink)
Died around age 230, XXX
96ToyoCam164K's Avatar
View 96ToyoCam164K's Photo Gallery
Man, dealers are so expensive...
As for valve cover gaskets, I would change them if you know thats it. Because one time, I got on the road not knowing it was leaky, 300 miles into the trip my car starts hesistating. Turns out, the plug wires had gotten swollen from the oil leaking in. Ended up having to do the tune up all over again...and since I really needed to change the wires as I thought the car would give out, I did it before changing the gasket.
Few months after that I had to replace the plugs again since I didnt fix it fast enough (I had the gasket fixed the same week, so it can happen pretty fast).
96ToyoCam164K is offline   Reply With Quote
