Info Request - Torque Specs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-23-2010, 05:19 PM   #1 (permalink)
Gameroom cash: $167485
iTrader Score: 6 reviews
View haux's Photo Gallery
What are the torque specs for the motor oil drain plug, transmission drain plug, differential drain plug, and differential fill plug. I couldn't locate any of this in the Haynes manual. Having some difficulty finding it in the camrystuff docs also. Maybe I'm blind or stupid... or both!
2000 Toyota Camry LE (Japan made) i4 5S-FE 367,000+ miles.
haux is offline   Reply With Quote
Old 01-23-2010, 05:42 PM   #2 (permalink)
rusty9's Avatar
Gameroom cash: $440405
View rusty9's Photo Gallery
snug, and then 1/4 turn will do it. there is no reason to "properly" torque those plugs since they arent under any stress.
rusty9 is offline   Reply With Quote
Old 01-23-2010, 06:02 PM   #3 (permalink)
Well, the reason would be so they don't leak? And so vibrations don't unscrew them. When I changed my oil the other day I noticed the plug was extremely loose. Not enough to untwist with one finger, but with a very small amount of force. I remember tightening it pretty hard last time too. *shrug* I made sure everything was more than tight enough this time, but thought I'd get the specs and do it properly so nothing leaks. It's harder to identify seal/gasket leaks when something stupid like a plug is leaking.
Old 01-25-2010, 09:55 AM   #4 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
The oil drain plug uses a fibre crush gasket, that said, 27 ft-lb in the FSM. Stamped steel oil pan.
Trans 30 ft-lb and could not find Diff. Both use an aluminum plug with aluminum washer to avoid drain plug from galling onto the aluminum. I coat the drain plug threads with pipe dope or RTV and re install.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 01-25-2010, 11:47 AM   #5 (permalink)
D.I.Y.'er since 2004
DxElite's Avatar
Gameroom cash: $259191
View DxElite's Photo Gallery
I've made a table sheet of Specifications for my 2000 Camry I4 5SFE.
I'll share it, you can download it here. It's PDF format so make sure you have acrobat.
Includes most fluid specs and torque specs for common maintenance and suspension parts. Mostly specs. for stuff that I've used so far. This is mainly for the I4 5SFE engine, V6 guys are on your own.
'00 Camry 5sfe DIY&Custom mods car : Cardomain
-Dual Bi-Xenon HID retrofit w/ custom halos - Custom LED tail light build - Custom black and clear corner lights
-Custom interchangeable Short Ram/Cold Air Intake -Whiteline RSB - Custom Rear Strut Bar
DxElite is online now   Reply With Quote
The Following User Says Thank You to DxElite For This Useful Post:
haux (01-25-2010)
Old 01-25-2010, 02:04 PM   #6 (permalink)
^ Pretty useful. Thank you!
