high rpm problem.... help me!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-23-2010, 08:04 PM   #1 (permalink)
View smilecow's Photo Gallery
Hello, folks
I have a rpm problem of a 99 camry 2.2l A/T.
When I start the enigine in the morning, rpm always goes to 2000. It doesn't matter whether it's cold or hot. After 3 min the engine is warmed up, rpm goes down
I cleaned iac valve and throttle body but nothing changed. what's the problem?
My second question is a transmission noise
When I change gear, P>R, R>N , I hear that the transmission hit something.
Somebody says that's because of worn transmission. Is it true? how to fix it? should I change clutch thing or transmission?
thank you for your reply
smilecow is offline   Reply With Quote
Old 01-23-2010, 10:29 PM   #2 (permalink)
Slowly learning....
View Retrospekt's Photo Gallery
The RPM could be normal. It doesn't matter whether it's 20f or 90f outside, it's still a "cold start" if the engine isn't previously warmed up.
My engine usually idles at 1,800 for the first 2 minutes in very cold temperature and 1,100-1,300 in not so cold, and for a shorter time.
The transmission: Sounds like a front motor mount. Climb under the engine and inspect it for cracks.
Or just have someone shift the trans while you look at the open mask. If the engine has too much movement, it will clunk. When you shift, the engine should jiggle a little bit, but not too much. I don't know how to give you an interval of how much is "too much". It's most likely the front motor mount though.
1996 Toyota Camry | 4 Cyl. 2.2L | Black Paint with Tan Interior | All Stock | DEAD at 155k. Broken Crankshaft/Main Bearing
Retrospekt is offline   Reply With Quote
Old 01-23-2010, 11:48 PM   #3 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
Like Retrospekt said, the idle thing may be more-or-less normal. What's she end up at once the engine is warmed up?
Not sure what you mean by "hit something". Like he said, look at the engine while someone shifts 'er back and forth, and see if the noise corresponds with major engine movement.
Old 01-26-2010, 06:33 PM   #4 (permalink)
The-Camry-Guy's Avatar
View The-Camry-Guy's Photo Gallery
Originally Posted by smilecow View Post
Hello, folks
my camry 94 revs to 2k at start-up unless its really hot then its just under that. it seems normal to me. its just getting itself up to optimum temperature for combustion.
does ur tranny sort of clunk when u change gears? next time have someone look at the engine when u change gear (ONLY IF U GOT AN AUTO AND BE CAREFUL) and see if the engine shakes at all. if so u might wanna check ur engine mounts (motor mounts). does the steering wheel vibrate sometimes? that also signs of worm mounts.
The-Camry-Guy is offline   Reply With Quote
Old 01-26-2010, 06:59 PM   #5 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
x2 to the mounts, mine does that and they are the problem it looks like.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 01-26-2010, 10:08 PM   #6 (permalink)
yea mine can get pretty bad. when im on the highway i cant do more than a certain speed or the wheelshake gets pretty bad. i can also sometimes see the windows shake as well as feel the car shake when im sitting in traffic. when i rev a bit it becomes slightly better.
are changing the engine mounts a big job?
