522t trunk release - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-23-2010, 10:54 PM   #1 (permalink)
View LUVLEXUS101's Photo Gallery
522t trunk release
Looking to upgrade my 12 year old alarm and I'd like to get this remote/power trunk opening option. Has anyone installed one of these yet?
http://cgi.ebay.com/ebaymotors/ELECT...Q5fAccessories
I'm fine with the electrical stuff but I'm not sure where I would mount it, is on the inside of the lid itself a bad idea? Not sure, open to suggestions guys.
LUVLEXUS101 is offline   Reply With Quote
Old 01-23-2010, 10:55 PM   #2 (permalink)
This is a picture from when I swapped lids and reattached my old cable
Old 01-24-2010, 11:25 AM   #3 (permalink)
View smilecow's Photo Gallery
I got 522t friday and I am going to install it wednesday.
I read the manual and it looks like that you don't have to remove any cable. just attache a new cable to the hook.
You should mount it straight so don't make the cable loose. In my case, I am not going to remove any old cable so mount it to the right side and make the new cable straight, no loose... and don't forget a relay.
If you already installed, could you post it?
smilecow is offline   Reply With Quote
Old 01-24-2010, 12:17 PM   #4 (permalink)
I ordered last night, hopefully I can install it this friday, if you do yours before then can you post up pictures of where you located the solenoid?
Old 03-25-2010, 12:19 PM   #5 (permalink)
#2!
Gameroom cash: $102128
View #2!'s Photo Gallery
Did any of you guys have success?
#2! is offline   Reply With Quote
Old 03-25-2010, 05:11 PM   #6 (permalink)
TOYODA KAMURI
the_professional's Avatar
View the_professional's Photo Gallery
Curious too, as I am contemplating doing this on my Legend, but the difference between the Camry & Legend is the Camry is cable operated, while the Legend is opened electrically.
i love my 1992 Toyota Camry LE 2.2L 5S-FE - 73K
9005 NIGHT GUIDE LOW BEAMS|FOG LAMPS|PIONEER HU&AUDIO|KEYLESS ENTRY
1995 Acura Legend LS KA7 3.2L C32A - 87K
SADLY, SHE HAS MUCH MORE MODS...
the_professional is offline   Reply With Quote
Old 03-25-2010, 05:23 PM   #7 (permalink)
#2!
If your Legend is electrically opened then there is no need to do this.
The problem I ran into with my Camry is that the length of pull required to pop the trunk is too long. The pull solenoid I got only gave about a 1/2". Plus where you set the cable has to have slack to generate the "snap" to pop the trunk or the solenoid gets stuck.
Old 03-25-2010, 05:49 PM   #8 (permalink)
Here is mine, it worked but I had to disconnect the rods for the key and the manual pull cable because my solenoid didn't provide strong enough of a pull.
before I ran the wire through, the popper is pretty hidden
Old 03-25-2010, 06:38 PM   #9 (permalink)
TOYODA KAMURI
Yeah, I know, since it already has a motor, I just need to wire the motor to get an impulse to open, the camry is a completely different story.
Old 03-25-2010, 08:42 PM   #10 (permalink)
#2!
What if it decides not to work?
Old 03-26-2010, 12:04 AM   #11 (permalink)
TOYODA KAMURI
^brings up a good point.
Old 03-26-2010, 08:35 AM   #12 (permalink)
#2!
My thoughts were to toss the bulky cable pull solenoids and find an actuator or servo that pushes or pulls the rod for the key.
or see if a ES300 electric lock fits.
Old 03-26-2010, 01:11 PM   #13 (permalink)
Then I crawl in and open it and reconnect the old wire.
