Antifreeze coolant in spark plug tube
I have a '96 Camry, 2.2L 5SFE, w/160K miles. Car started running awful, noticed the #2 spark plug boot was sticking out a little, pulled it out and a good tablespoon or more of antifreeze came out with it. I think all the sub zero starts during that cold weather spell we had here in Omaha the last month perhaps made something fail. Anyway, temp was normal while driving, and oil on dipstick looks good, but antifreeze was down about a quart. Car seems to run fine for the first few minutes until the coolant builds up again and causes misfiring of the spark.
1) Is this most likely a cracked head, or just cracked head gasket, block failure, or a failure of the spark plug tube seal? I was told by Toyota service that there is no way coolant could get into the spark plug tube without a massive failure of some kind.
2) If it is a head failure, I could put in a new head from King Cylinder Heads, complete with cam & valves, but Toyota doesn't provide casting numbers on their heads and the matching head from King has a pretty generic spec to me, i.e., Camry, Solara, Celica 1994-2001. Is there a high risk of a mismatch somewhere? Any opinions on King Cylinder Heads?
3) Also since it's at 160,000 miles, is it silly to replace the head without just pulling the engine and servicing pistons also? Power seems good and no oil burning that I can tell. I have replaced a head before on a Nissan, but don't have an engine hoist to pull the engine. I was hoping to fix it properly without having to removing the engine if possible.
