Help I need some help bad 94 Camry 5SFe (california emmisions)
the title says it all. did the heads got rebuilt block,
runs great starts everytime...but major oil leak coming out of distributor.
Replaced the o-ring on distributor seems it was brittle and cracked when touched. No leak at first took it out on highway and seems like the leak is worse.
drips at idle shoots in a stream whe reved up and pressure is on called dealer parts counter to ask if there is a seal they said o-ring told them I replaced it, they said distributor is bad, Is that right?
$517 @ dealer
is junk yard distributor ok?
new or remanufactured $50 difference @ NAPA $250-299
if no to junkyard is reman ok or go with new money is tight but i want to do it right... if this is the problem
Thanks
