Solara passenger door electric question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-24-2010, 09:37 PM   #1 (permalink)
View arkin's Photo Gallery
So guys, my first post on these forums, been reading for a while now, finally ran into a problem that prompted me to register an account
I recently fitted LED lights in my passenger door, I thought it was safe to take the 12V from the window control. I had always been taught that blue was live/positive, green was ground and used this theory in fitting my LED's. I placed 4 in my speakers if anyone is interested.
Anyway, turns out green wasn't ground, and after a few days of the LED's working, they stopped.
I removed all the stuff, took the switch apart to find the switch terminals had been blackened by short circuit maybe? I'm not an electrician, it was a failed attempt at putting some nice lights in my car.
The window switch has completely stopped working, and the lights have, I found that if i ground the window switch to the metal chassis I can still get the window motor working, but this isn't really a solution. It just tells me that maybe ground was damaged? I don't know.
Can anyone help?
arkin is offline   Reply With Quote
Old 01-24-2010, 09:51 PM   #2 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Rule #1: Buy a multimeter before playing with wires!
Rule #2: If you don't know what your 100% doing when it comes to electronics, don't do it alone!
Rule #3: The12Volt.com is your friend.
Rule #4: RED is + and BLACK is - 99% of the time. No blue and green.
If I remember right, The blue and green wires have to do with the power door locks. IMO, I'd check the12volt.com for information on where you can get a proper 12v constant source and then check it with a multimeter. Then check ALL the fuses. Chances are you just blew a fuse somewhere...hopefully.
'07 Honda Ruckus Big Bore
Old 01-24-2010, 09:59 PM   #3 (permalink)
I didn't mention that I checked the mutlimeter on all of them and they are live.
I also checked the interior fusebox and no fuses relating to the doors/windows/locks were blown.
The only problem seems to be ground is missing?
Old 01-24-2010, 10:03 PM   #4 (permalink)
I just looked up my wiring diagram.
http://www.the12volt.com/installbay/...tail/2124.html
Windows Up LF=Green, RF=Green/White
Windows Down LF=Red, RF=Red/Blue
So there is still a question of what solid blue is?
And also, what does LF/RF mean?
Old 01-24-2010, 10:20 PM   #5 (permalink)
Freakin Scooters
LF= left front, RF=right front. Toyota uses negatively swicthed circuits. This means that most of the switches for electronics are always getting 12v when you put a multimeter to them. The way the circuit is completed is by pressing the switch and giving the circuit a path to a ground point. Make sense? So i doubt the ground is truely "missing". I guess we need to know what solid blue is.
Looks like you've done a decent job checking the basics. Time for a solara owner to chime in.
Old 01-24-2010, 10:30 PM   #6 (permalink)
Just might refresh someones memory if they can see an image lol
If I add a ground to that first green wire, the window will go down but not up.
If I add a ground to that last red wire, the window will go up but not down.
The connector block is what I was using for my LED's, they did work at first. Fail, I know.
Old 01-25-2010, 12:04 PM   #7 (permalink)
There are no toyota electricians out there?
