Howdy,
Toyota 1994 2.2L 4 Cyl. ~110KM
So I was driving down the highway last night when my car abruptly became ill. The only thing I noticed at the sudden instant was that the OIL light came on, while all other lights remained off. After the tow we tried to start the car, but it would not turn over. The garage told me that the engine was seized due to a timing belt failure. (They added that they were able to turn the crank shaft (right?) **less** than 90deg.)
I know that interference engines typically die as a result of this, BUT from my research it seems the 2.2L 4 cyl. engine is not of that type. (Correct? I checked on gates.com.) There was no indication (strange noises, etc) leading up to this that failure was eminent. In fact, it was working great!
Of course my gut says to take the car to the scrapper because of age and what not, but I want to understand this a little more before I do so. (Part of me has become quite attached to the car.)
So my question is, if the timing belt goes, does the engine go with it? Why would only the OIL light come on as opposed to check engine, charge, etc? (The other lights show on start up as part of normal operation.) What other causes would see this failure? Anything I can try to give er a shot in the dark before giving up? (I'm grasping at nothing here, but are there any silly methods of un-seizing an engine temporarily for a very very short ride?)
Plan B is a hopeless attempt to convert it to an EV one day.
Brett
