Is the pad thinner on the inside? If so the caliper piston is sticking, causing accelerated wear. The caliper/anchor pin/glide rails may need cleaning and lubing. And when you change directions, it typically causes pads/calipers to shift a bit. That might have helped.
It may be time to rebuild the calipers and replace all the rubber parts, especially over 100K miles.
Originally Posted by asphalt victory
so while going to see theise big ass waves today i took the camry down this crator ridden road i parked then shortly after i got going again and there was a scraping noise
it sounded like smothing draging so i pulled over and looked underneth nothing got going again and pulled over in a parking lot checked out that whole area
i was thinking i bent a dust sheild or somthing
then i backed up and put it in drive and no more noise?
i did notice that the inner brake disc side was warn deep with a lip on the edge
