this is a long story so bear with me.
Back in '05 I purchased this Camry. I made it 19.6 miles from the "dealer" when the engine blew a piston thru the top of the motor.
Purchased a used engine with 46,000 miles to put in the thing. After many troubles getting my mechanic to put it in the dumb thing wouldn't start. spent 2 years figuring out what was wrong. Ended up being the distributor and MAF. Got running FINALLY only to find out the head gasket was "folded" causing an over-heating problem.
Had that replaced and the "Mechanic" left off a couple of plug wires. Took back to him to have him check timing due to lack of power. He eventually got it to run 1/2way acceptable, but still lacking the GO!! it should have. Couldn't get him to do any more at this point.
Drove car for 7 months in '09 before it started flashing the o/d light while going down the road and running at 4000 RPM at 50 mph. Parked car for the night and when getting back into it the next morning, it still ran at a high rpm for about 1.5 miles then it was ok for a minute. Actually rode at a lower rpm than usual at 55 mph for about 1-2 miles at which time the thing died and now will not start. Couldn't get any spark from the distributor so I checked the coil and wasn't getting spark there either.
Now I am stuck with the decision of where to start with the replacement of components. Anyone with any ideas?
Thanks in advance for any help in this matter.
Hopefully I don't have to blow it up!! LOL
This is a U.S. car.
