Electronic Transmission Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-27-2010, 11:48 AM   #1 (permalink)
View fatherof4's Photo Gallery
I have a '94 Camry w/ AT and have a strange problem. My transmission is having trouble downshifting. The strange thing is when I press the brake pedal the Reverse Light comes on the cluster panel and the indicator light that tells you when a bulb is out. The car will downshift on decrease in speed but changes only after decent to heavy vibration of the transmission stalling as it downshifts. This is only a problem when the brake is applied. If I slow down going up an incline it doesn't give the same issues. Transmissino upshifting is not having any problems. Is this a sensor issue or possibly the solenoid, or is it a ECU issue. Any help is greatly appreciated.
Thanks,
Tim
fatherof4 is offline   Reply With Quote
Old 01-27-2010, 11:20 PM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Pop the trunk. Example the wires at the bend. Are there wear?
Thanks,
Tim
Old 01-28-2010, 12:11 AM   #3 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
check the kick down cable make sure it not too loose
^ and leaving it that way!
