Transmission clunk - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-27-2010, 03:20 PM   #1 (permalink)
View A Del Pints's Photo Gallery
Transmission clunk
My cars transmission has been acting weird. I have a 1994 camry V6 le. When i shift from park to drive after just starting it up there is a very loud clunk. Today this clunk didnt happen and my car started to rev whenever i hit the gas and i had to drift back a hill. now it is fine. Is this an indication of a transmission about to go?
A Del Pints is offline   Reply With Quote
Old 01-27-2010, 06:24 PM   #2 (permalink)
Gameroom cash: $814001
View zythr's Photo Gallery
Are you shifting into drive while the car is on an incline?
zythr is online now   Reply With Quote
Old 01-27-2010, 06:59 PM   #3 (permalink)
rusty9's Avatar
Gameroom cash: $440405
View rusty9's Photo Gallery
open the hood and shift from park to reverse to drive. see if the engine moves back and forth a lot. could be the front transmission mount(or any other engine mount for that matter), its a piece of shit mini hydraulic shock absorber that tends to blow out after 16 years =)
rusty9 is offline   Reply With Quote
Old 01-27-2010, 11:11 PM   #4 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Also check the condition and level of the ATF. how long ago has it been changed and the pan wiped clean? The strainer ever changed?
Old 01-27-2010, 11:27 PM   #5 (permalink)
Gameroom cash: $167485
iTrader Score: 6 reviews
View haux's Photo Gallery
^^ I'd start with that.
I've had the whole rev thing happen in Reverse two times a few years ago. I think that time is also when I got a P0770 code. As far as I can tell, replacing the transmission fluid helped a ton. The clunking could definitely be a sign of low fluid too.
Are you getting any check engine codes?
2000 Toyota Camry LE (Japan made) i4 5S-FE 367,000+ miles.
haux is offline   Reply With Quote
Old 01-28-2010, 06:40 AM   #6 (permalink)
yea i have the check engine light took it to autozone to get the codes they said bad sensor but this could all be making sense now
