DIY: GEN3 1MZ Replacing Steering Rack and P/S Pressure Hose (w/pics) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-28-2010, 11:29 PM   #1 (permalink)
Nervous's Avatar
Gameroom cash: $275064
View Nervous's Photo Gallery
3rd Generation DIY: GEN3 1MZ Replacing Steering Rack and P/S Pressure Hose (w/pics)
Before starting I want to say personal "thank you" to 73sport for his steering rack replacement writeup:
http://www.toyotanation.com/forum/t108185.html
That was big help!
One snowy day I found a red stain on white snow under the car, driver's side. I have gen3.5 V6 Camry 1996, 141 Kmiles. First thought – transmission or differential! Thanks God, this was just (well, yeah right – “just”!) leaking steering rack. Leak was from the driver’s side boot. Fortunately, it wasn’t that bad: I could top off steering fluid once in three weeks, especially if I turn my wheels all the way right during parking (in this case, it didn’t leak).
Anyway, time to replace the original 14 y.o steering rack. Plus (well, honestly it is “minus”), I already knew that my original P/S high pressure hose is slowly leaking (it leaked from the place, where metal pipe is connected to a rubber hose).
It has been leaking for a year already, but since it was very slow I hadn’t replaced it yet. But the part was bought (the aftermarket one: the OE part costs $400 at dealers, even online!).
I shopped for reman steering rack. I had several options. One: dealer reman rack, $300 + $150 core + tax (local MD dealer). Later I found out that several online part shops sell the same unit. OEM reman racks has brand "Maval" and you can find these units on importec.com and autohausaz.com. Partznet.com (actually this is a dealership in PA) does not ship racks at all, 1sttoyota wanted $100 for shipping (since they are in WA and me is in MD). As an alternative - rockauto.com that sells aftermarket remans. I chose Beck Arnley for $218 + $111 core with very cheap shipping - just about $9. Hopefully, it will last at least several years. At least they give 3 years/50K miles warranty on this rack, which is pretty good (better than 12 mo / 12 Kmiles AC Delco warranty or 12 mo / 18K miles A1 Cardone warranty).
Another parts I decided to replace: OEM stabilizer bar bushings – 2 pcs (OEM part# 48815-06021), OEM tie rod ends – 2 pcs (45046-29255), OEM stabilizer links (48820-33010), OEM P/S pump union bolt (90401-16008) and P/S pump –to-high pressure hose gasket (44327-12010). All OEM parts were bought at partznet.com. I also bought a set of metric nitrile O-rings in the nearest "Harbor Freight Tools", since I knew that I would need to replace some O-rings.
A side note. Don't use aftermarket parts that includes ball joint parts, such as tie rod ends, stabilizer links or ball joints. 6 mo ago I replaced original 13 y.o. stabilizer links with aftermarket ones. Look, what happened with them now (in just 6 months!) (low row - aftermarket, up row - original 13 y.o.):
Compare with original old ones. Old ones are in better shape! So, use OEM here, or you would replace them each year. It is not a big deal with stabilizer links, but for tie rod ends you would need to do alignment every time.
Before raising your car put your wheels straight and secure the steering wheel by the seat belt or rope. I used the seat belt. It is not really necessary to secure it very firmly, just enough to avoid significant movements of the steering wheel.
Removing O2 sensor from the rear side of the engine is also a good idea to do before raising the car. Disconnect connector and using 22 mm wrench unscrew and remove it.
Lift the car. Note, you need to lift your car as high as you can - this will simplify your job. My jack is crappy and lifts maximum to 14". I ordered a new jack that lifts up to 20" but at the moment of work I hadn't got it yet. However, I found a way to increase lifting height even with my old jack. Just put your jack under the sub-frame instead of dedicated place for jack. This gave me additional couple inches of clearance. Don't forget to put jack stands! Don't leave the car lifted by the jack only!
Disconnect battery (a negative wire) before starting work to avoid any unpleasant surprises from SRS
So, I lifted the car and put it on jack stands. First of all inspection.Amazingly, but original tie rod ends and stabilizer bar bushings were in pretty good shape. Tie rod ends showed a little bit of oil oozing out of rubber boot if you press on it, but boot was not destroyed.
Bushings were soft and technically I could leave them on place, but since I already had bought new ones I replaced them anyway. I also inspected ball joints and lower control arm bushings - ball of them are original and still in great shape.
Remove both wheels and plastic protection (fender apron, 2 pcs 10 mm bolts).
I removed the stabilizer links (since I needed to replace them, if otherwise it is enough just to disconnect them from the sway bar). For original links it is necessary to use hex (allen) wrench to put it in the center of each link's axis and to use wrench on the nut preventing the axis from rotation by holding that hex wrench firmly. For my aftermarket crap this wasn't really necessary and I disconnected them by using deep 14 mm socket.
Disconnected tie rod ends. Needed to remove a cotter pin first and then unscrew a castle nut (17 mm). I used tie rod end puller and I would recommend this way to everybody instead of using a hammer. Tie rod ends went out with loud "bang" sound.
Now needed to unscrew 4 bolts holding the sway bar. First of all, using some paint, mark location of bushings on the sway bar. I didn't lower the engine cradle as 73sport did. I just used 12 mm wrench with a foot pipe extension to break the bolts. There is not much space there especially for the bolts close to firewall. You can rotate wrench from 6 o'clock to 5 o'clock only (counter clockwise).
For opposite bolt there is more space (let say from 11 o'clock to 7 o'clock).
So, this takes some time. Need to remove all 4 bolts (2 on each side), remove the clamps and bushings (since I was going to replace bushings).
From the passenger side, unscrewed the 12 mm bolt that holds returning pipe on top of racks mounting bracket.
From the driver's side detached from frame a charcoal canister's rubber pipe and just put the end of it onto differential housing to clear the way.
Now the fun part - unscrewing 2 big 19 mm bolts holding rack in place. The nut is in front and the head of the bolt is in back, behind the sway bar. Since sway bar is unscrewed it was easy to lift it up to get access to the bolt's head. Started from the driver's side's nut. Put 19 mm socket, 10" 3/8" breaker bar and extended it by 6' pipe from Home Depot. With loud "crack" I loosened it. Now put 19 mm wrench on the nut and a ratchet with 19 mm socket on bolt's head from opposite side. As I said needed to lift the sway bar to clear access to the bolt's head. Unscrewed and removed the bolt and nut.
Passenger's side nut was much more "fun" to remove. Because of engine mount there is not place to put socket with breaker bar on the nut.
I tried to use gear wrench instead, with pipe extension. It slipped. I almost rounded the nut, at least seriously damaged it. It took me some time to put wrench back on the nut (since it was damaged). I decided to go another way - to loose it from bolt's head side. Put a 19 mm socket with 10" breaker bar + pipe extension on the bar's handle. This was the moment of time when I needed bigger clearance: I'd be able to use longer extension pipe. This took me some time as well, since it was very inconvenient to pull the breaker bar with a pipe from underneath the car. But finally I made it.
The nut was almost destroyed and I went to ACE Hardware to buy a replacement. Home Depot do not have much metric bolts and nuts and even ones it carries are crappy (grade 2). ACE Hardware has big assortment of high quality (grade 8) metric nuts.
(here, on photo there is another broken bolt; I broke it removing P/S fluid reservoir)
Unscrewed bolt connected steering shaft with pinion. I definitely recommend to use wobble extension bar. It gives about 20 degrees of additional freedom in tight space.
Disconnected in-out tubes from the rack, using 17 mm wrench. First disconnect the lower one and this will give you more space for the upper one. Be ready for mess, put oil pan under the car to catch all P/S fluid.
Removed the old rack by twisting, pulling and pushing it in all directions.
So, now I switched to replacing pressure hose, since it is much easier to perform when rack is out of the car.
Disconnected lower end of high pressure hose from a metal tube that goes into the rack. Did it from underneath the car. By 22 mm wrench I held the end of the pressure hose and by 17 mm (or 19 mm?) wrench unscrewed the connector on metal tube. A little bit more mess possible here, so be ready.
Disconnected the upper end from P/S pump. Need to unbolt union bolt using 22 mm wrench. It is good idea to hold pressure port union (which is the place where union bolt is bolted in) by 24 mm wrench, since it might be loosened instead of union bolt itself. Be careful not to destroy steering pump pulley: it is pricey.
Detached upper part of pressure hose from the engine by unscrewing a nut on the top of the rear engine's side.
Detached middle part of pressure hose from the engine.
Detached rubber vacuum hoses coming from pressure hose to engine. Mark them first!
Removed the hose.
New hose requires transfer of some parts from old hose (OEM hose includes everything; maybe that is why it is so expensive):
Transfer mounting brackets from old to the new hose, as well as vacuum stuff and shield of lower hose's part.
Put new hose in place, attach to the engine, connect rubber vacuum hoses back. Rplace O-ring, attach to gear-side pipe using 22 mm wrench and 17 or 19 mm wrench (forgot which one exactly).
Connected high pressure hose to P/S pipe. Use new gasket and I used new union bolt.
Installed new tie rod ends on new rack. I used a piece of carton where I put the old rack and marked where tie rod ends are. I also counted how many threads are between jam nut and end of the thread. I also counted how much turns old tie rod end should do before come out. Finally, I measured the distance between jam nut and end of the inner tie rod. And still I am not sure that my wheels are aligned properly, so, planning to visit alignment shop anyway.
As to the centering rack - my rack was perfectly centered out of the box.
Now time to install a new rack. Make sure the passenger's side mounting bracket (with steering rack bushing) is at the same distance from driver's side mounting hole as on the old rack, otherwise it could be hard to put that bolt back (if it is easily movable then it is not a big deal; my was pretty much unmovable).
Start pushing new rack from the driver's side. Be careful to not destroy thin pipes on the top of the rack. It would be necessary to turn and twist the rack. Could be helpful to have someone at opposite side of the car to track and direct rack's movement. Do not pull by tie rods!
Once the rack at the place, shift it a little be toward the passenger side and connect the sliding yoke back to the rack. Move the rack back to its place. Put bolts and nuts back. To do so it is necessary again to raise the stabilizer bar to clear access to the bolt holes. I applied anti-seize paste on the bolts before tighten them.
Connect in and out tubes (pressure and return ones). Before this, I replaced both 10 mm O-rings at the ends of the tubes. DO NOT miss the port! Even though ports have different diameters, it is possible to put smaller nut from one tube to a bigger port and even tighten it! I almost did this and couldn't understand why I can't connect another tube! Figured out by looking at photo I made before disassembly (one more reason to take pictures during the process).
Finally, put back 12mm bolt supporting the return line on top of the passenger side rack's mounting bracket.
Put stabilizer bar bushings with mounting brackets back and bolt them. Again, will take some time since there is no much space there especially for the bolt close to firewall. Again I applied anti-seize paste on every bolt.
Connect tie rod ends to knuckles, put stabilizer links back.
At this point I also put the removed O2 sensor back, since I was going to start the engine soon. Don't forget to apply anti-seize paste on O2-sensor's thread.
New rack is in place:
Well. Almost done. Time to bleed to system. Disconnect return-to-reservoir hose and using vinyl hose connect it to the metal part of return-to-reservoir tube. Direct another end into a bottle or oil pan. Fill the reservoir, put someone behind the wheel and tell her to start engine for several seconds. Once tank is almost empty stop the engine, fill again and now tell the helper to slowly turn steering wheel from one side to another. Make sure she is ready to stop engine at any time and don't leave reservoir empty. I used a couple 1 quart bottles of Dexron from Walmart and then reconnected the return hose to the reservoir.
That is it. Attach rubber hose from charcoal canister back to the frame. Put aprons back, put wheels back, lower the car, get a test drive and do alignment. Send or bring the old rack back to get core charge back.
Total time was 2 full days from morning to midnight, but everything I did w/o help (besides flushing). Next time could be faster (hopefully, this won't be soon!)
Good luck!
PS. BTW, I needed to buy some additional tools. First of all I bought a tie rod puller on ebay and it worked perfectly for me:
I also found out that I don't have 19 mm and 24 mm wrenches and 3/8" 10" breaker bar. Plus, I always wanted to have a good set of screwdrivers. I had a bunch of Sears gift cards and gladly spent them on Craftsman tools.
Camry Sedan 1996 LE V6 1MZ - 170 Kmiles
FOR SALE, Sedan/Wagon parts
Nervous is offline   Reply With Quote
The Following 5 Users Say Thank You to Nervous For This Useful Post:
AlmightyCamry777 (02-03-2010), bcny168 (01-29-2010), N/A Camry Sleeper (08-14-2011), peshwa (01-29-2010), rty (01-30-2010)
Old 01-28-2010, 11:47 PM   #2 (permalink)
Gameroom cash: $167485
iTrader Score: 6 reviews
View haux's Photo Gallery
Excellent write-up! This will be very helpful if I end up replacing the rack on my 2000. I'm thinking the procedure will be similar.
2000 Toyota Camry LE (Japan made) i4 5S-FE 367,000+ miles.
haux is offline   Reply With Quote
Old 01-29-2010, 01:12 AM   #3 (permalink)
A camry n00b
peshwa's Avatar
Gameroom cash: $257859
View peshwa's Photo Gallery
Awesome DIY and write up Mr.Nervous...now I am NOT nervous if it comes to replacing my rack...LOLZ :-)...Thanks also to 73sport....he is one of the most helpful guys around at TN.....VOTE FOR A STICKY :-)
1995 Camry DX L4 178,6XX miles and counting each mile.... acquired 05/25/2007 at 129K miles
2004 Mazda6 I4 5-Speed Manual 115,500 miles acquired 01/21/2011 at 109,XXX miles
peshwa is offline   Reply With Quote
Old 01-29-2010, 02:07 AM   #4 (permalink)
View smilecow's Photo Gallery
GREAT!!!!!!!! I'll use this post as a manual in the future
smilecow is offline   Reply With Quote
Old 01-29-2010, 08:57 AM   #5 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
Glad that was helpful -
Seriously, my first step eould have been the car wash and blasting as much of that stuff off as possible!
All those rubber parts look infected! Too much time soaking. They'll mush let the rack and sway bar move. . .
Did you replace them?
Good Job!
73sport is offline   Reply With Quote
Old 01-29-2010, 09:15 AM   #6 (permalink)
Nervous's Avatar
Yes, replaced all bushings I could reach during the process (sway bar's and rack's ones) as well as stabilizer links and tie rod ends.
Old 01-29-2010, 10:52 AM   #7 (permalink)
V8'sRGone
73sport's Avatar
One question and one comment:
What did you mark under the car that was of signifigance?
Tie Rod End:
I can swing a hammer very accurately! If you don't have puller as pictured above, I'll advise a sharp crack to the knuckle before EVER USING A spliting fork (pickle fork) and damaging the joint AND destroying the boot for certain!
As for measuring anything; the goal is the return the total length of the rack from Tie Rod End to Tie Rod end back to where it was on the original rack. This way you can drive it to the shop within a couple of days and not chew off the tires! Taking a few extra steps as I did also ensures the steering wheel position returns pretty close to where it was.
I think I should write an artical on setting the toe-in in the driveway as I can get just as close as the guys at the shop with a few simple tricks. Serious!
Ever notice how the NASCAR boys do it after a bump with the wall? Its pretty easy but it takes time know what to look for. They go 200+mph when done and must have it darn close!
Old 01-29-2010, 01:23 PM   #8 (permalink)
Nervous's Avatar
My jack stands are on sub frame, not on the floor I wrote about this in my DIY
Old 01-29-2010, 02:01 PM   #9 (permalink)
bitch please
DarkMastyr's Avatar
View DarkMastyr's Photo Gallery
Originally Posted by Nervous View Post
[COLOR=Gray]
One snowy day I found a red stain on white snow under the car, driver's side. First thought – transmission or differential!
My first thought would have been: "goddammit it's that time of the month again for the lady"
Oh and nice DIY.
1994 Camry 2.2L LE Auto
DarkMastyr is offline   Reply With Quote
Old 01-29-2010, 02:05 PM   #10 (permalink)
Nervous's Avatar
Ha-ha!
Old 01-29-2010, 09:15 PM   #11 (permalink)
Born to Drive
EEngineer's Avatar
Gameroom cash: $426353
View EEngineer's Photo Gallery
holy crap...i can't imagine how must pain it was to do all that work with literally no space.
bravo!
My Once Beloved Camry
Rest in Peace
NEW ES300 5SPD SUPERCHARGED BUILD THREAD
EEngineer is offline   Reply With Quote
Old 02-03-2010, 10:28 AM   #12 (permalink)
Nervous's Avatar
FYI: my little investigation of available racks on market:
Remanufactured steering rack & pinion - which brand?
Old 03-17-2010, 09:25 AM   #13 (permalink)
View golfinator's Photo Gallery
Replacement Racks
Replaced the rack on my '97 with one from NAPA ($194 + tax) back in 8/02 at 61K mi. Just noticed small leak starting at 150k mi. Called NAPA and they said will swap out for new one at no charge, so thanks for the post(couldn't find his name when I went looking) that mentioned the lifetime guarantee from NAPA.
golfinator is offline   Reply With Quote
Old 03-17-2010, 11:06 AM   #14 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
added to sticky great write-up!
HaHa
Old 03-22-2010, 06:22 PM   #15 (permalink)
View tomalex's Photo Gallery
Thanks for taking the time to document all this for us at the Nation!
tomalex is offline   Reply With Quote
